Member # 62985
Th350
Will all TH350 internals swap with another TH350? Wat I have is a cracked case on one that is good and another one that is not so good, but it has a good case. Can I swap the internals from the one to the other? Thanks for any info.
If you put lipstick on a pig it's still a pig. |
Member # 62985
It doesn't have any wires coming out of it. What is the difference between the 350 and the 350c? I think they both came out of mid 70s chevys.
If you put lipstick on a pig it's still a pig. Last edited by biggraypig; 02-13-2006 at 06:00 PM. |
Member # 13786
The 350c has a lock-up convertor, different case and a few internals were different. As long as it does not have an electrical connector going to it you will be ok.
Member # 62345
If you are going through all that, why not just rebuild the good one?
[B]86 CJ7[/B]: 8" lft, 38 TSL, D44 F&R, Lockers [B]95 4Runner[/B]: 32" tires [B]87 K30[/B]: 18" lft, 44 Boggers, 15x18 Real Wheels, 502BB, t400/NP208, D60F, 14bff rear [B]KFX400[/B]: +3 front, TCS Shocks, +4 rear, CarbonFiber Beadlocks |
