Eaton h072/h110 question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-11-2006, 08:02 AM   #1 (permalink)
Member # 68098
This board has a lot of good info on the eaton axles I could not find anywhere else, thanks in advance.
The questions I have are.
1. Will the center section from a h110 or h135 fit into a h072 housing?
2. Would the ring and pinion from a h110 or h135 fit a h072 carrier?
3. Would the side/ spider gears from a 14 bolt fit in a h110 or h135 carrier?
4. Is the gmc military m135 axles the same as the h110 or h135. I am asking about the centersections here.
I am a truck puller, and have been running the h072 for 7 years now. I want to regear the truck to a 6.14 ratio but I don't want to get rid of all my 8 hole rims, and was hoping that I could make somthing like the m135 center work in my h072 housing. There are a few of the m135 axles around here and they have the 6.14 ratio I am looking for.
swany388 is offline   Reply With Quote
Old 03-11-2006, 08:34 AM   #2 (permalink)
Member # 38212
The h110 is a lot bigger than the h072. The h072 can be gotten in 4.10,4.56,5.13 and maybe 5.89. I have had all but the 5.89.
1967K10 is offline   Reply With Quote
Old 03-11-2006, 12:57 PM   #3 (permalink)
Member # 29210
Send a message via AIM to Davethorik
according to this 1963 book, you can get 5.83's for the H072:
thanks to u2slow for the scan
:laughing:
Davethorik is offline   Reply With Quote
Old 03-11-2006, 03:20 PM   #4 (permalink)
Member # 38212
So according to that a 1ton SRW could have 5.83's with a 3spd tranny? Is 5.83 a avaliable ratio for D60's??
Old 03-12-2006, 10:20 AM   #5 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
5.86s are available.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 01-31-2008, 10:01 AM   #6 (permalink)
Member # 107619
Eaton H110
I need info on this rear as much as possible.
Last Minute is offline   Reply With Quote
Old 01-31-2008, 10:28 AM   #7 (permalink)
GMCTruxrule's Avatar
Member # 51243
Well start searching, Google is a good place to start.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 01-31-2008, 10:33 AM   #8 (permalink)
Member # 78331
What kind of info? I found this post by Davethorik. It's about 4 years old.
Originally Posted by Davethorik View Post
The H110 was an optional axle in C/30 trucks and some step vans. It had the standard 8x6.5 lug pattern, and a massive 12.25" ring gear. I am unsure of axle size/spline count. A quick way to tell it apart from an H052/72 is that the 110 has a welded on diff cover from the factory, & the smaller ones have a bolt on diff cover.
dirtchicken is offline   Reply With Quote
Old 01-31-2008, 11:06 AM   #9 (permalink)
Member # 107619
I am looking
I have a newer one with disk brakes and a square tubes. It has 5.42 gears. Can I get axles for this if I break one what all did they come out in? Are they strong. this one is 10 lug.
Old 01-31-2008, 03:27 PM   #10 (permalink)
Member # 29210
Actually, I am wrong
The H110 doesn't have 8 lug wheels. They are 10.
:laughing:
Old 02-08-2008, 05:10 AM   #11 (permalink)
Member # 107619
Where
Can I find the info saying that the H110 is a ton rear end? Please help. I have been searching the net with little luck this is about the only place anyting pops up. Some guy are telling me its not a true ton rearend.
Old 02-08-2008, 08:31 AM   #12 (permalink)
Member # 9402
eaton
the 5.83 gears --are in a 10 lug application --center section same as 3/4 and 1 ton --only place i have seen these are in a box trk --or bread truck
RON WHO ?? don't little jimmy rig your rig!!
partsjunkie is offline   Reply With Quote
Old 02-08-2008, 09:43 AM   #13 (permalink)
Member # 78331
Google does wonders.
Old 02-08-2008, 01:14 PM   #14 (permalink)
Member # 107619
H110
Can any one tell me where I can find an article that I can copy that says that the H110 came out in a factory 1 ton truck application. I have tried google and have not found much information. Anything that you guys can do i would really appreciate it.
Old 02-08-2008, 01:50 PM   #15 (permalink)
Member # 106663
Buy a manual?http://cgi.ebay.com/ebaymotors/1967-...spagenameZWD1V
Filthy McChevy is offline   Reply With Quote
Old 02-08-2008, 02:14 PM   #16 (permalink)
Member # 51243
Considering that it came in both 3/4 and 1 on applications, I who cares what other people say? Does it work for your needs? If so, run it.
Old 02-08-2008, 02:38 PM   #17 (permalink)
Member # 29210
I think we're getting stuff confused here. The H110 was an optional axle in C/30 only...and older ones at that. Pre '73 afaik. They are 10 lug, not 8. If there are any 8 luggers floating around, that's news to me...the oem setup with the H110 on the C/30's was 5 lugs up front, 10 rear like the modern day 3500HD's. I don't know about gears. I used to have a service manual, but lost it in a move...I'm sure it would have more detail that I can't fill in.
:laughing:
