Code Reader for 1995 S10 Blazer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-01-2006, 09:54 AM   #1 (permalink)
Member # 55884
Send a message via AIM to Blazer707
Does anyone in norcal have a code reader that would work on a 1995 s10 blazer? i would pay and all that good stuff i just wanna hook it up and see what i have to replace right now.
-Thomas
1979 Hilux, 5.29's spool'd F/R, duals 4.7's, TG 4inch all around, bobbed bed. *UNDER CONSTRUCTION* Build thread VVV
[URL="http://pirate4x4.com/forum/showthread.php?t=950421"]http://pirate4x4.com/forum/showthread.php?t=950421[/URL]
[URL="http://davezoffroadperformance.com/"]http://davezoffroadperformance.com/[/URL]
Blazer707 is offline   Reply With Quote
Old 04-01-2006, 09:55 AM   #2 (permalink)
Member # 46267
Send a message via AIM to nathan_454 Send a message via MSN to nathan_454
autozone scans for free
[QUOTE=trampas]...we just need to tear down the walls, open the gates, and let them walk in, in groves.
But not before we spend sufficient time inventing a car that runs on Mexican people. :D[/QUOTE]
nathan_454 is offline   Reply With Quote
Old 04-01-2006, 10:02 AM   #3 (permalink)
Member # 54558
95 is OBD I, just use a paperclip
ReadyMix is offline   Reply With Quote
Old 04-01-2006, 10:02 AM   #4 (permalink)
Member # 54558
Old 04-01-2006, 10:23 AM   #5 (permalink)
Member # 46267
oh, i guess it is, your right. some were some werent. damn transition year.
Old 04-01-2006, 11:35 AM   #6 (permalink)
Member # 55884
so get an obd 1?
-Thomas
Old 04-01-2006, 11:37 AM   #7 (permalink)
Member # 46267
get a paperclip
Old 04-01-2006, 12:34 PM   #8 (permalink)
Member # 55884
a paperclip? sry im new to all this electronic stuff im use to just basic wireing and carbs. i called autozone, and they sell the obd 1 for only 40 bucks, so i just need to know if the obd 1 is the exact one to use cuz the guy said he did not know.
-Thomas
Old 04-01-2006, 12:51 PM   #9 (permalink)
Member # 34058
on the paper clip you gound a serton terminal and it will cause a serton light to blink on the dash a set number of times and also for differant lengths you then take that look in a manual and it will tell you what it means. i believe thats how it works.
black4x4 is offline   Reply With Quote
Old 04-01-2006, 03:59 PM   #10 (permalink)
Member # 55884
on the 1995 s10 blazer there is only 1 thing that works its some 3,500 thing that the chevy dealership uses and of course 1995 is the only year that u need it.
-Thomas
Old 04-01-2006, 04:37 PM   #11 (permalink)
Member # 9991
How close to livermore are you? I have scanners for all GM!
[url]www.scotthansen.net[/url]
MrWillys is offline   Reply With Quote
Old 04-01-2006, 04:41 PM   #12 (permalink)
bremen242's Avatar
Member # 28687
if it is like my '94 pontiac, you need a OBD I scanner.. the paperclip thing doesn't work. I have an autoxray scanner that scans it.. I paid like $200 for it...
bremen242 is online now   Reply With Quote
Old 04-01-2006, 04:43 PM   #13 (permalink)
Member # 9991
Originally Posted by nathan_454
get a paperclip
A paperclip will only read stored codes and not let you see the function of the device. You probably already knew this though!
Old 04-01-2006, 05:46 PM   #14 (permalink)
Member # 5110
Get WinALDL ( http://winaldl.joby.se/ ) and make a cable
http://techedge.com.au/vehicle/aldl160/160serial.htm
...then just use your laptop.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote
Old 04-01-2006, 05:50 PM   #15 (permalink)
Member # 9991
You can buy the cable from www.akmcables.com . I use datamaster instaed of winaldl. I'm sure they're both good, it's just the one I started with.
Old 04-02-2006, 08:01 PM   #16 (permalink)
Jamus2's Avatar
Member # 12943
Send a message via AIM to Jamus2 Send a message via Yahoo to Jamus2
You must have what some call the OBD 1.5. I've heard of people having trouble with them. not OBDII but different from OBDI. I have used a paperclip and WinALDL both on my 94 Blazer no problem.
[QUOTE=papee]This game IS real life for us web wheelers.:flipoff2: [/QUOTE]
Jamus2 is offline   Reply With Quote
