Member # 19933
not hard at all just take out factory rivets and bolt new hangers on, i think ORU was the brand. you might have to move your rear axle forward 1" depending on lift or you can just cut the fender
frank
'85 Yota Truggy-350 TBI,Turbo 400, Stak 5.44:1, D60s |
Member # 68512
you can modify your existing hangars. you run your existing springs, and you get about 4" of lift. ORD, DIY4x, SKY, and others make one for you if you wanted to buy one. here is a tech article explaning how to do it. http://coloradok5.com/shackleflip.shtml
89 s10, flogged regularly 94 burb, tow rig |
Member # 34555
Look at the CK5 write up. It is simple to do. I used the ORD kit www.offroaddesign.com and the DIY www.diy4x.com kit looks great.
Run when you can, walk if you have to, crawl if you must; never give up. Last edited by cbbr; 04-19-2006 at 09:43 AM. |
Member # 64748
Yea it is a simple thing to do.
The most time consuming portion is getting the stock hangers off, sometimes the rivits dont like to come off, I broke an air hammer doing mine but other than that it is simple. I have pictures and a write up if your interested in seeing it but the ck5 write up is probably better than mine, I have never read it but I have to assume it is.
I caught your Jeep thing now it BURNS when I piss! |
Member # 70275
I have installed 4 ORD kits and would recommend their products. Their kits give either 2.5 or 4" of lift depending upon which kit you order. You do use your stock springs. The kit is not technical, but not easy. Getting the rivets off, especially on the drivers-side, can be a bear and you have to drop the gas tank to install the drop brackets.
I would rcommend a cutoff disk to cut trenches into the tops of the rivet heads. Then you can use an air hammer with a sharp knife to cut the heads off. Again, because of the spare tire well, the driver side has less room to work and is more difficult. You need to egg out the holes in the frame to accept the 7/16 bolts provided in the kit. Best to use a die-grinder for this. On my 1990 Suburban with a 14FF, the wheel sits perfectly in the well and 35's look nice with a 4" lift. PM me with any other quesitons you might have. |
Member # 34555
I tried the air hammer and gave up. i used a grinder to just grind the heads off and hammered the rivets out.
Run when you can, walk if you have to, crawl if you must; never give up. |
Member # 68512
i vote for torch. it took less than a few minutes total on my blazer with a torch. and if you are doing the homebrew method, you dont even need to take the brackets off the frame. i went with DIY's kit cause it gets rid of sucky stock style shackles.
Member # 65521
i took the front hanger off of a 3/4 ton and mounted it on on the rear with some thick angle iron to beef it up on the bottom of the frame. a little time consuming but really strong.
UNDER CONSTRUCTION 76 CHEVY CREW 454 4spd 241/205 doubler Rocks both welded 56s front 63s out back Full hydro 15" bead locks 46" MT CLAWS UNDER CONSTRUCTION 94 Z71 2 1/2 rockwells disk brakes 49" michelins full hydro divorced ford np205 custom SAS |
#12 (permalink) |
Member # 43029
Im using offroaddesign.com shackle flip hanger and there heavy duty shackles and the hardest thing for me was re hanging a full damn gas tank...I have 8'' springs + the 4'' lift from the hangers and my axle is still perfect in the middle and no problems at all..I was running a 42'' tire and never rubbed.......
#14 (permalink) |
Member # 64748
no the ORD is for the back spring only (by the way I think they are better than DIY, they are powder coated and have one hell of a customer service, the ORD comes with larger bolts than the DIY too).
Most people use 52" springs from a Blazer in the front to get the 4" of lift, myself, I had 6" lift springs so I used them along with 2" blocks in the back to level out the height. I think that is what you were asking right??
#15 (permalink) | |
Member # 68512
and people, why does eveybody think that 52" springs only come from blazers? they came in ALL 1/2 tons 2WD and 4WD, and some 3/4 tons, 73-87 or possible later.
89 s10, flogged regularly 94 burb, tow rig Last edited by Donahue; 04-21-2006 at 04:13 AM. |
#16 (permalink) | |
Member # 17507
micah [url]http://AustinK5.net[/url] [URL=http://www.austink5.net/phpBB/modules.php?set_albumName=micah&op=modload&name=gallery&file=index&include=view_album.php]my gallery[/URL] 84 K5 350 10:1 on propane 700r4 Klune-V 205 60/14 4.56 detroits hummers 42TSL's |
#17 (permalink) | |
Member # 68512
#18 (permalink) | |
Member # 17507
#19 (permalink) | |
Member # 64748
this is certainly cheaper but cheaper is not always better. http://img333.imageshack.us/img333/2...pinstal3kj.jpg You look at his set up and that is a pic of my ORD kit, which do you think is better? You put enough shear force on his and it will either break, tear, or both. I am sorry but that set up he has in his pic is junk.
I caught your Jeep thing now it BURNS when I piss! Last edited by avainaffairs; 04-22-2006 at 09:24 PM. |
#20 (permalink) |
Member # 54093
I used the 4" ORD shackle flip with home made 7.5" shackles with 63" springs and I got about 4-5" of lift. I did get rid of them because I inboarded my springs but even with the stock springs and shackles, you get a better ride and better flex.
'91 Cherokee Sportsman/4600 Thanks to: SinisterDiesel.com RuffStuffSpecialties.com HorsepowerJuice.com RDMOffroad.com |
#21 (permalink) | |
Member # 68512
i never recomended cutting the factory bracket. if you read i said i went with the DIY4x setup for the shackles. sorry for the big pic, but this is my setup.
