427 Rasied block buildup - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2006, 05:36 PM   #1 (permalink)
Member # 26710
We used to work on a lot of heavy trucks (C60 and C70 series) . As a result, there are a couple of 427 raised block truck engines sitting around. After hearing of some guys using these to build big (540 ci) inch mud runners. I thought about collecting the parts for a buildup. Is there some chart that tells the possible ci's and what components are used? I saw one stroker kit nearly 600 cubes....
Rocky
1310monster is offline   Reply With Quote
Old 04-27-2006, 06:17 PM   #2 (permalink)
b454rat's Avatar
Member # 16536
Strokermotor.com is one site. Never really checked into tho, so can't say too much. I know you can do alot to them....
b454rat is offline   Reply With Quote
Old 04-27-2006, 06:19 PM   #3 (permalink)
KILLER"B"3's Avatar
Member # 54970
The biggest You can build the truck block 427 is a 496 pushing the limit 502 not recommended.. It can't tollerate the 4.5 bore needed to make it a 540. Built as a 496 it can be made into one hell of a stump puller with gobs of torque.
stuck in the garage
KILLER"B"3 is offline   Reply With Quote
Old 04-28-2006, 02:55 AM   #4 (permalink)
Member # 34756
A couple slightly related threads:
/forum/chevy/332916-intake-427-tall-deck-truck-car-b.html
/forum/chevy/333223-tbi-conversion-big-block-oval-port.html
Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing.
4x4Poet is offline   Reply With Quote
