corperate 10 bolt ratio - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-04-2006, 06:57 PM   #1 (permalink)
Member # 73683
Question corperate 10 bolt ratio
how do i figure out what gear ratio i have in my axles? it is a 3/4 ton with a th350 and np 208 the rear axle is a corperate 10 bolt.
powerline-k9 is offline   Reply With Quote
Old 06-04-2006, 07:06 PM   #2 (permalink)
Stuckle's Avatar
Member # 57804
pull the cover
count teeth and divide them
Stuckle is offline   Reply With Quote
Old 06-04-2006, 07:11 PM   #3 (permalink)
Member # 63800
3/4 tons never came with 10 bolts from the factory. either it's not a 3/4 ton, it's a not a ten bolt or your axle has been swapped.
jack up one rear tire, spin it around twice. count how many times the driveshaft turns. that's your ratio.
"I’m more flux-core than hard core." -- rustywagoneersdotcom
OffRoad is offline   Reply With Quote
Old 06-04-2006, 08:19 PM   #4 (permalink)
Member # 37519
They only came in the front, not the rear
I think powerline-k9 is
[COLOR="Black"]..............[/COLOR]/´¯/)
[COLOR="Black"]............[/COLOR],/¯../
[COLOR="Black"]...........[/COLOR]/..../
[COLOR="Black"].....[/COLOR]/´¯/'...'/´¯¯`·¸
[COLOR="Black"]..[/COLOR]/'/.../..../......./¨¯\
[COLOR="Black"].[/COLOR]('(...´...´.... ¯~/'...')
[COLOR="Black"]....[/COLOR]\.................'...../
[COLOR="Black"]......[/COLOR]''...\.......... _.·´
[COLOR="Black"].......[/COLOR]\..............(
[COLOR="Black"].........[/COLOR]\.............\
mudslinger99 is offline   Reply With Quote
Old 06-06-2006, 05:08 PM   #5 (permalink)
Member # 73683
my bad
i apologize, i have a 14 bolt in the rear and a 10 bolt in the front. is there a site or something i can type in the V.I.N #?
Old 06-06-2006, 06:47 PM   #6 (permalink)
Banned
trkklr77's Avatar
Member # 29016
not realy.
first look for a ratio tag on the bolts for the cover, its about 1"x1.5", it will have the teeth count and ratio. do the same for the front cause the axles probaly match.
or pull the cover of and count the teeth around the ring and then pull the pinion and count those teeth, divide ring teeth x pinion teeth = ratio
there are only a few rations avalible
3.54
3.73
4.10
4.56
maybe 4.88
5.13
maybe 5.38
it will be very obvius if you have 4.10 or ### higher you wont go very fast but the truck will jump on it.
