Wait this ain't Tx..
oil pressure?
I'm probably being paranoid but I don't want to replace another motor so its ok this time
Newly rebuilt 383, has about 600 miles give or take. When the motor is warmed up to about 180*, the oil pressure when stoped at a stop light is at 13-15, which is about at 600-700rpms. At 2000rpms the oil pressure is at 40 and at 2500rpms it is at 45. That seems right, but I just don't remember it getting down to 12 or 13 when ideling before? What generally is acceptable and if 12-15 is fine, than what is low oil pressure, 0? Thanks
"There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter." -Ernest Hemingway '69 FJ-40 - under construction |
#2 (permalink) | |
Banned
Member # 51243
Oil pressure with a stock pump should run somewhere in the range you are having.
What you are describing above is normal. A lot of people will tell you to run a high volume oil pump, but on a stock engine that doesn't see redline duty on a regular basis, a stock oil pump is adequate to keep your motor oiled.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
I thought it was ok, but I didn't want to burn this motor up. I like it too much
I've always read that the high volume oil pumps could run dry when crawling at the steep angles and low rpms that we do. Thanks for the info.
Beaver Pleaser
Member # 13645
the story I heard is the HV oil pumps will suck the pan dry going through the quarter...
1972 GMC Submarine 383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez Inclined to brute force attack a 70* incline with a Quadrajet 1997 GMC K3500 Suburban Turbo 5.3 in the works / 4L80E / HP60 SAS / PROJECT TOWHOE |
