Member # 40230
350 TBI fuel lines: Where can I find them?
I have been searching high and low for the fuel lines that run off the TB and into the lines below the cab and I cannot find them. Anyone know where I can find them? Thanks.
-Greg
Toys and Tools |
Member # 14848
in about 2 bazillion chevy pickups. check the junk yard or the dealer. Most the yards near me literaly have dozens of tbi trucks/vans...
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case 1988 Bronco,in progress |
Member # 278
I've done three things for TBI lines:
1) Used hacked up stock lines from the original engine I swapped in 2) Used some replacement "barbed" fittings... I want to say it was centech but wouldn't swear to it 3) Used some unbent lines I got off ebay. They are pretty thick for fuel lines and are the first I've really required a bender to adjust. I really like the unbent lines because I can route them where I'd like... as well as being very thick. |
From what I can tell these will work.
http://store.summitracing.com/partde...0&autoview=sku Im going to go this route when I put my fuel cell in. Currently I have the lines from the donor truck going down to the frame rails where they tie in with rubber line to the stock hard line. Seems to work fine for now. But once I get the fuel cell in Ill have to convert to AN lines so might as well replace the whole line.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and fox coilovers, 8.1 liter 496 bbc/4l80e/BWtcase. DD/towrig |
Evil Twin
i bought the AN adapters and ran all AN lines, can switch from SS/flex to hard lines as needed with the AN stuff..
Mike Yager - Jeep TJ Build Up - Ecotec, Toy axles etc.. Ecotec - Technical Info E450 Ambulance VRAY (YAger RV) VRAY 2006 E450 - Ambulance Cummins Diesel Swap |
Member # 40230
I have been to a bunch of junkyards and all the ones I found were kinked or had the same problem I had; the SS wrap had been burned off in a few spots and the rubber was starting to bubble/crack.
I think I am going to make my own lines. The new summit store is 30 minutes south of me and I am going to pick up all the supplies tonite. What size fittings/unions fit the existing TBI unit and fuel lines. Also, what size line should I buy? Thanks. -Greg
Toys and Tools |
