Installing a Gen1 350 inplace of a Gen2 350w/tbi - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-06-2006, 04:45 PM   #1 (permalink)
4544x4's Avatar
Member # 34587
Send a message via AIM to 4544x4 Send a message via Yahoo to 4544x4
I want to use the TBI setup on the Gen 1 350.Truck is a 90 GMC V3500.I was wondering if all the sensors and intake from the Gen2 Will bolt right on the Gen1.
And any horror storys would help, So i know what to avoid.
Thanks,
Windle
Chupa la verga
4544x4 is offline   Reply With Quote
Old 08-06-2006, 06:24 PM   #2 (permalink)
Home Built's Avatar
Member # 5734
Send a message via Yahoo to Home Built
I think the only thing that might be different is the angle of the 4 center bolts on the intake are more staight up and down ,compared to the earlier 350's. You can use the intake but you will have to re-drill the holes to the correct angle to make it work, I did this on my truck and had no problems with leaks or anything. I don't think there were any differnces untill after 92 so you should be ok.
[B]Chicks dig body Damage...[/B]
74 Chevy Fullsize, 39.5 Irocs, D60/FF14bolt, Locked, Lifted, Stroked, Fuel Injected, Hydro assist. with lot's of body damage...
Home Built is offline   Reply With Quote
Old 08-06-2006, 08:07 PM   #3 (permalink)
Member # 26545
Send a message via AIM to Beater_K20 Send a message via Yahoo to Beater_K20
center 4 bolts on the 86+ engines (86 was carbed, 87 started TBI) are drilled at 72* from the intake flange, where pre-85 engines were drilled at 90*. nothing else different. the first real difference started in 96, with the introduction of the Vortec intake flange, everything before that is pretty much bolt on.
93 Chevy C2500 - 10 bolt/14FF 5.13s Detroit rear
454/80E/NP241 - SAS in progress
Beater_K20 is offline   Reply With Quote
