how do I remove hinge pin in 99 suburban rear barn door - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2006, 11:34 AM   #1 (permalink)
4rnr's Avatar
Member # 34860
I f'ed up my pops rear barn door with a trailer
now ive got one from a junk yard, but the junk yard torched the backets so I have to use the ones I have. so I have to remove the hinge pin from the rear hinge. its a pin that goes through the hinge and the door pivots on it. Ive been smacking it with a 2lb sledge but no luck. Is there a trick?
Sorry for the gay Q, im a toyota guy and dont know of any chevy places (less hardcore) to ask this.
thanks
92 4rnr 3.4 auto duals 37's...
72 fj40 some stuff.
4rnr is offline   Reply With Quote Quick reply to this message
Old 08-12-2006, 06:28 PM   #2 (permalink)
Member # 67907
Did you get the c clip off? As I recall ours had a c clip on the bottom, I may be wrong
The Beepster
Jeepermat is offline   Reply With Quote Quick reply to this message
Old 08-13-2006, 04:55 AM   #3 (permalink)
4rnr's Avatar
Member # 34860
no c-clip
72 fj40 some stuff.
Old 08-13-2006, 12:19 PM   #4 (permalink)
Member # 71051
Grind the head off, use a punch and hammer it out, install new pins
you may need to put some heat on it, they tend to get rusted solid in there.
or you maybe able to hammer it out from the bottom-up.
ALLJACKEDUP is offline   Reply With Quote Quick reply to this message
Old 08-13-2006, 07:38 PM   #5 (permalink)
4rnr's Avatar
Member # 34860
been trying from under but cant a good swing on the hammer, ill get evil on them!!
72 fj40 some stuff.
Old 08-14-2006, 04:06 PM   #6 (permalink)
Member # 71051
Grind the head off the top of the pin, if you have a air hammer with a old bit grind that bit down to fit the pin and try that. but grind the head off the pin and hammer the pin down not up.
