Member # 77531
Ram Assist Q:
So I have a K5 with a D60 front and 14FF rear. I want to do ram assist. Question Will a 1.5in bore with a 6in stroke work or do I need bigger?
And if anyone has any other tips thats great as I will attempt to do myself.
K5: locked and geared, one-tons, LT1, doubler, 42s youtube.com/user/onetonk5 |
Member # 41764
D60's need an 8" stroke, but you still have to limit them down to about 7"'s.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5 Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between No one is ever gone if they are always remembered. JasonPayneMemorial |
Member # 5730
yup on the 8"--and the smaller the ram the faster and less power it has--the bigger the ram the slower it is but has more power--
that said I have the 2" ram and it does excellent except the very fast turn during my desert running. I just have to plan ahead.
Blazer, lock-right 60 front, welded 14 rear, ORD crossover, 400/STaK WTO 2" hydro-asst, 39 IROK's |
Member # 77531
thanks for the help. you think I should go 2in then? Im running 42's and prob. 50/50 trails and sand. I just a lil scared of having to slow of turning.
Member # 5730
i think an 1 3/4 would be fine. if i would do it again thats how id go
Member # 41764
I went the 1.75" route, not sure how it will perform but Ive heard of some issue with the 5/8" rod in most 1.5" rams deflecting causing the seal to leak. I drive mine around town and to and from trails as well so the 2" was going to be a little slow for me as well without going to a KRC pump or something.
Member # 77531
assist
the help is great, one last Q: after the box it tapped. (chevy K5) which hole is which of the top and bottom?
Member # 5730
Its trial and error---hook up the lines and turn the wheel (with fluid in it of course) and if the tire wants to go the other direction flip the lines. it makes it easier if the axle is on jackstands too.
Member # 77531
ok
well i think I got all the help i needed to start, thanks everyone.
scoobydann I saw your K5 on (peoples projects) looks great love the cage nice hydo assist I take it that pic was your first run? if so how did it go? anything you will change?
Member # 77531
ok
#13 (permalink) |
Member # 41764
Machined steel spacers, not the easiest and not the route Im trying first but IMO that would be the best option(stainless if care to machine it may even work better so it won't corrode).
Im trying the leaf spring bushing cut down route with some heavy washers, some have done it and say it works, we will have to see.
#14 (permalink) | |
Member # 5110
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893 |
#15 (permalink) | |||
Member # 5730
Over all I am VERY happy with the way she turned out.--now I need bigger tires
#16 (permalink) |
Member # 77531
should I stard a new thread? I wana see some pics of your trac bar. Also what rear springs are you running and what front shocks(to soft?) I was going to get the procomp 3000's good bad? im poor, on king coils here
#17 (permalink) | |
Member # 5730
the rear springs are 57" ford 1/2 ton springs. I ran the rancho 5000's (equivilant to the procomp 3000) and hated them. way too stiff, especially with an off the shelf lift spring. personal expirence only. I dont think I have ever been happier with spending a little bit more on good shocks. it really does make a difference. on the front I have the Bilstein 5125's with 255/75 valving, and for my application I think I am going to go a little bit stiffer shock. The soft springs and soft shocks don't go well. But, it's a HELL of a lot better, but I think I can go more. You don't have to spend mucho $$ on shocks but the little bit more you spend the MUCH better the shock will be. I will say this from personal expirence--if you go with some bilsteins go through Mad4WD.
