need brakes - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-10-2006, 08:14 AM   #1 (permalink)
Member # 79080
need brakes
I have a 85 4runner with D60 under it and i need better brakes any ideals
chevyrunner is offline   Reply With Quote
Old 09-10-2006, 08:20 AM   #2 (permalink)
Member # 79080
Unhappy need brakes bad
[QUOTE=chevyrunner]I have a 85 4runner with D60 under it and i need better brakes any ideals.I also put a 1ton mastercylinder on it to.
Old 09-10-2006, 09:17 AM   #3 (permalink)
bigyellowjimmy's Avatar
Member # 53682
60 front or rear? does the 60 have stock brakes and what is the other axle/brakes?
bigyellowjimmy is offline   Reply With Quote
Old 09-11-2006, 11:07 AM   #4 (permalink)
Member # 79080
The D60 has 3/4 ton calipers front and back
Old 09-11-2006, 11:41 AM   #5 (permalink)
Member # 79080
Old 09-11-2006, 12:50 PM   #6 (permalink)
Member # 53682
Ummm, you're confused at your own quote?
Anyway, you've got 3/4 ton discs front and rear on D60's and a 1 ton MC and you need better brakes?
Are they bled?
Old 09-13-2006, 06:27 AM   #7 (permalink)
Member # 79080
yes they have been bled i have ran about 4 bottles of brake fluid in them. I may have to keep bleding them until i get brakes
Old 09-13-2006, 08:11 AM   #8 (permalink)
Member # 72684
i think you might need more info for some help
like
what the problem is
low pedal ?
no stopping power?
are you running stock mc?
do you still have the stock proportion valve in the lines?
you may not have the volume of fluid needed for caliper travel for the rear
NOT ALL NEWB'S ARE NEWB'S
mazdab2600 is offline   Reply With Quote
Old 09-14-2006, 06:14 PM   #9 (permalink)
Member # 79080
no stopping power going down hill.I still have the factory brake lines on it and i have put a 1ton mc on the 4runner brake buster.there is a man in a club near where i live that showed me his and it works fine.
Old 09-14-2006, 07:56 PM   #10 (permalink)
Member # 79156
I've seen alot of write ups on it and the stock yota booster should be fine. Did you make sure the push rod is going into the booster/MC deep enough? Its gonna have to push a little more fluid than it did with the stock toyota MC, but you should still be able to do it. Might even read some write ups on it just to see if you missed anything important.
Evan
`92 Toyota/Chevy looking thing. fullsize axles 38.5" boggers, onboard welder, bed mounted john deer radiator.
EWhytsell is offline   Reply With Quote
Old 09-15-2006, 07:39 PM   #11 (permalink)
Member # 14584
Your saying that you have to really stand on the pedal to get it to stop?
Yes my truck is environmentally friendly.
It lets most of the environment in the truck with you!
6869704x4 is offline   Reply With Quote
Old 09-16-2006, 08:11 AM   #12 (permalink)
Member # 15404
Are you sure your booster is working? Did you blead the perportioning valve? My budys 4-runner was the same way untill he realized the valve had a breather on it too.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
