u joints arent in alignment - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-14-2006, 07:35 AM   #1 (permalink)
Member # 13091
Send a message via Yahoo to Fast68 Send a message via Skype™ to Fast68
i noticed under my 77 that the u joints in my rear driveline arent in alignment
they are off by about 60 degrees or so, rotated
its a factory 203 and th350 rig, fixed yoke still
is it ok like this or should the joints be aligned ?
thanks for anything
Im parting 1980s 4x4 Toyotas & chevies 1960s-80s - cars too! text 2176717792 to get to me quick
Fast68 is offline   Reply With Quote
Old 09-14-2006, 08:47 AM   #2 (permalink)
FrankenToy's Avatar
Member # 36822
thanks for anything
You mean NOT like this ]-------[ ?
Literally, just pull the d-shaft apart, turn the slip end to match the t-case end and push back together. They should be aligned to minimize vibrations...
Seems the fools are in charge now and they demand a high tariff... Me
FrankenToy is offline   Reply With Quote
Old 09-14-2006, 09:45 AM   #3 (permalink)
Member # 13091
yeah like that
the caps at one end of the shaft arent phased the same as the caps at the other end of the shaft
so i take it they need or must be in alignment ? or ?
or doesnt matter ?
i dont notice any balance problem or anything driving it ever
thanks
Old 09-14-2006, 11:53 AM   #4 (permalink)
FrankenToy's Avatar
Member # 36822
Yes, the u-joint caps should be in a straight line with each other.
Old 09-14-2006, 12:09 PM   #5 (permalink)
Member # 15404
or doesnt matter ?
Obviously it will work if out of alignment because you are driving it...but it will lead to early bearing wear because of the vibrations. It will take a long time to kill a pinion bearing or t-case bearing but the little needle bearings in you u-joints will go out much faster.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
