sm465 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2006, 04:34 PM   #1 (permalink)
Member # 52058
sm465
The saginaw 3 speed colum shift behind my screamin inline 250 is getting replaced by a sm465, i have all the goodies, correct bellhousing, flywheel, starter ( if the tooth count is different, havn't checked yet). Question is will the throwout fork work from the 3 speed, are the throwout bearings the different? Also will I have to carve out the whole center of the floor, or just enough room for the shift tower? She's a 78 c10 (2wd) Dont give me any "its not a 4x4" crap, my other rigs is a jeep, just answer the tranny swap question.
tekmoe is offline   Reply With Quote
Old 09-20-2006, 06:36 PM   #2 (permalink)
Member # 13786
How tall is the floor at the moment? Usually the manuals have a removable center section that is about 4'' tall. If you have this then all that is necessary is a hole enough for the top of the tower about 5'' circle I think.
Throw out fork and bearing should be the same---along with the clutch assy. Shouldn't have to change the flywheel. All that should change is the bellhousing, trans, and driveshaft
KWTMECH is offline   Reply With Quote
Old 09-20-2006, 06:50 PM   #3 (permalink)
Member # 9483
If I'm not mistaken the top of the 465 will stick through the floor a little bit. the boot that they came with is huge. the factory hale is oblong ~4.5x6
[B][I]"Wheel hard" G.D.I [/I][/B] Buggy -35 spl hp60, drv flgs, bear knuckles, spooled 4.88, .030-327, sm465 wms 203(3:1)/205 NWF triple stick, high angle drvshft's, 35spl 60 rear spool, PSC full hydro, 42"iroks, recentered h1 dbl's. 99 4x4 24v dodge for towing. [URL="http://www.gdi4x4.com/"]GDI4x4[/URL] [URL="http://www.pirate4x4.com/forum/showthread.php?t=626027"][COLOR="Orange"]my buggy redo[/COLOR][/URL]
riksnacjnow is offline   Reply With Quote
