6.2 diesel specs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2006, 09:56 PM   #1 (permalink)
Member # 30246
6.2 diesel specs
I did a few quick searches and can't find anything. And loaned out my book
I need the torque specs for the rocker rails.
Also, for the intake (I think it was near 25-30 ft lbs... but can't remember exactly.)
Any help would be appreciated.
CheyKev
[I]A well adjusted schizophrenic![/I]
ChevyKev is offline   Reply With Quote
Old 09-22-2006, 10:27 PM   #2 (permalink)
cuc-v's Avatar
Member # 70310
Send a message via AIM to cuc-v Send a message via Yahoo to cuc-v
intake 31ft lbs
im not sure wat the diff. is but these r ur options for the rocker rails;
-rocker arm cover........26ft lbs
-rocker shaft bolts.......40ft lbs
86 chevy short bed, 14bff/10b, 350/465/208
86 m1028 14bff/10b, 6.2/400/208
cuc-v is offline   Reply With Quote
Old 09-23-2006, 12:25 AM   #3 (permalink)
Member # 30246
Thanks - the "cover" is basically the valve cover bolts. the shaft bolts are the rails I was asking about.
This is also what I found if anyone else is searching:
1989 6.2 Diesel Engine Torque Specs
All foot Lbs unless indicated.
Bellhousing 30
Cam Gear 75
Cam Thrush Plate 17
Connecting Rod nuts 48
Crankshaft Pulley 30
Cylinder Head (3 steps) 20 / 50 / +90 degrees
Exhaust Manifold 26
Flywheel bolts 65
Front cover bolts 33
Glow Plugs 10
Injector Lines 19
Injector Nozzle 50
Injector pump Retaining nut 30
Injector Pump Gear bolt 20
Injector Pump Baffle bolt 33
Intake Manifold 31
Lifter Guideplate 18
Main Bearing caps inner 110 / outer 100
Oil Pump Drive bolt 31
Oil Pump Retaining bolt 65
Rocker Arm Cover 16
Rocker Arm Shaft 40
Thermostat Housing 35
Vibration Damper 200
Water Crossover to Head 31
Water Pump to Cover 31
Water Pump Plate to Pump 16
Vacuum Pump Retaining nut 31
Oil Pan bolts - inch lbs
rear 2, 84
others 204
CheyKev
