Member # 79727
14 bolt FF disk brake
wondering what websites or parts that other pepole have used to do a disk brake conversion on CORP. 14 BOLT FF. I have striped off the drums and am ready to order.... have been considering TSM kit ...... ANY IDEAS
THANKS |
Member # 34555
http://www.blackwidowperformance.com has full kits.
Run when you can, walk if you have to, crawl if you must; never give up. |
Member # 34555
If you need just the brackets talk to Gravel Maker or go look at www.ruffstuffspecialties.com
Member # 8108
Check out this great link from Billa Vista. It has all of the info you need to do the swap right and cheaper than buying a kit. You can use a weld-on bracket from Ruff Stuff Specialties or their sweet bolt-on adapter that uses the calipers and rotors that Billa Vista did.
That is the setup I will be running on the 14-bolt I picked up this past week. Good luck.
AtoZ Fabrication, Inc. 570-385-3931--shop 570-385-3932--fax MADE IN AMERICA---and proud of it!!! We also offer the best service and prices available on: Advance Adapters Clayton Offroad Suspension Raceline beadlocks wheels Amsteel Winchline and accessories ORI struts and Radflo shocks Read my story about Todd at F&S Racing in the Bad Sellers forum |
#7 (permalink) | |
Member # 53682
Great Lake Offroad (260) 387-1428 |
Member # 1919
TSM and Blackbird are both overpriced so far it isnt even funny.
GreatLakeOffroad is THE man for brake conversion brackets. I have never purchased from him but I have had similar brackets custom laser cut so i know what is involved. |
Member # 1792
Ruffstuff has lots of brackets and perches for cheap.I will be ordering my diskbrake brackets from them.They are 3/8" and have a bend so you don't need the spacers.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers. |
Thanks for all who gave me props here and as always its nice to see the other vendors of this board taking a professional nuetral stance.
Just to give you guys an update. I am no longer using DOM tube spacers (and to answer another question no it is not because they ever sheared off bolts ) We have actually been in the process of refining all our products due to wanna bees copying our original designs. And since I am in the laser/fab business we are now taking up the space w/ 4 small angles that have been laser cut for a precise fit and welded to your brackets. What does this mean? Well for one it means no more having to use a BFH to try and get a bent bracket to line up correctly only to have your pads wear at a quick uneven pace. Would the pads not lining up correctly cause bad braking performance? The answer is yes and in the long run more money from your pocket. Not to mention thick formed steel typically develops minute cracks at the bends that can stress and fracture over time. New low pricing to be released soon. Thanks guys, Shawn
http://www.greatlakeoffroad.com Don't Forget Your Discount enter Pirate10 to get your 10% discount off |
Member # 42026
I have the brackets from Ruff Stuff Specialties and they seem to work pretty well...I like the bend as well. They don't come with bolts though. For rotors you can just get the fronts from an OOBS Chevy 3/4 ton at a parts store, I think I used the ones for an '80 model. You can you either the calipers and pads from the front of the same model truck or if you want a built in e-brake get the calipers/pads for a 76-78 Cadillac Eldorado.
#12 (permalink) |
Member # 9835
You guys are in the dark ages, as always the latest greatest tech is on the binder board
![]() http://www.pirate4x4.com/forum/showt...88#post5938188 . |
#14 (permalink) | |
Member # 1919
#15 (permalink) | |
Member # 9835
#16 (permalink) | |
Member # 188302
Did you use diy4X.com's Dana 70 disc conversion kit on your 14 bolt axle? Just curious to your set-up and the hub dimensions. Anybody have input on hub dimensions for a 14 bolt/Dana 70 if they are different?
Bad Ass Black Truck Local Mosquito Control |
#17 (permalink) |
Member # 188302
In case anybody is wondering why i asked for hub dimensions i reckon i should say the diy4X.com Dana 70 disc conversion kit comes with a rotor said to be larger hub diametered.
"This kit will include the rotors as well. The rotors are not an off the shelf item. Dana 70 hubs (that we have seen) require a larger center hole. This is the reason for non standard rotors. Rotor availability is no problem we have them on the shelf now! This kit uses the same caliper as our 14BFF kit. A 76-78 Eldorado caliper or a 71-87 GM 3/4 ton 4x4 front caliper."
#19 (permalink) | |
Member # 63837
SUPPORT THE BLUE RIBBON COALITION!!!! Specialty off road shop. In house fabrication for just about anything you might need. SAS Kit coming soon! 712-472-0200 Order line 712-479-2252 Tech support www.diy4x.com |
#20 (permalink) |
Member # 51243
Another vote for Shawn at Greatlakesoffroad.
Got mine from him, perfect fit.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#21 (permalink) |
Member # 161463
Be careful what year 14 bolt FF you get. mine is out of an <84 and it has a slightly larger diameter between the backing plate mounting and the spindle. This caused my spacers to not work so instead i got some 3/4'' x 1/2'' I.D out of galvanized 1/8'' steel tubing. Its not a big deal,Just an issue you may encounter.
[URL="http://www.pirate4x4.com/forum/showthread.php?p=14188243#post14188243"]Parting out 88 3/4 ton chevy pick up [/URL] |
