Couple questions about an '89 K5... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-28-2006, 10:20 PM   #1 (permalink)
Member # 30390
This thing isn't as easy to troublshoot than my older K5. First, the 'service engine soon' light comes on intermittently. What sensors are linked to this light?
And...
The transmission hesitates for 3-5 seconds before going into drive, is this normal? Thanks!!!
Shaun.
Edit: It's a 1989 fullsize blazer, 350TBI, 700R4.
1990 K5 Blazer, Built 383, 39.5 Boggers, M12000 etc....SOLD!!
2014 RZR 800HO with numerous upgrades
1981k20 is offline   Reply With Quote Quick reply to this message
Old 09-29-2006, 07:45 PM   #2 (permalink)
Member # 30390
Anyone?
Old 09-29-2006, 08:06 PM   #3 (permalink)
Member # 13786
Check the fluid level with the engine running, or you may have to change the filter and gasket. For the light, you'll have to scan the computor and get some service codes.
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 09-29-2006, 09:20 PM   #4 (permalink)
Member # 30390
Thanks!!
Old 09-30-2006, 10:44 PM   #5 (permalink)
Member # 5110
The "scan tool" for your truck consists of a bent paper clip shoved into the ALDL port under the steering column. Do a google search and you will be able to find out how to do it and what the codes mean.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 10-01-2006, 04:34 PM   #6 (permalink)
Member # 30390
I tried searching and came up with nothing. Any links? Thanks.
Old 10-01-2006, 05:26 PM   #7 (permalink)
Member # 5110
I found all this in the 1st and 2nd links that came up when searching ALDL codes on google.
http://www.google.com/search?hl=en&q...=Google+Search
http://www.aldlcable.com/
http://www.s10blazers.com/service_engine_soon.htm
Turn engine/key off
Jumper the top right terminals of the ALDL port
Turn key on but engine off
Watch check engine light for blinking.
1-flash then 2-flashes = code 12 which means the self diagnostic in the computer is working.
It will then flash other codes.
Code:
Code
System / Circuit
Problem
 Code 12
System OK
If this code continues to Flash after 3 times, no codes are stored in the Computer, and everything should be fine.
 Code 13
Oxygen Sensor
Check the wiring and connections to the sensor.  Check for a sticking throttle position sensor.  Replace Sensor.
 Code 14
Coolant Sensor
High Temp.
Check the wiring and connections to the sensor.  Find cause for overheating, Replace Sensor.
 Code 15
Coolant Sensor
Low Temp.
Check the wiring and connections to the sensor.  Check ECM Connection too, Replace Sensor.
 Code 21
Throttle Position Sensor
High Voltage
Check for sticking TPS Plunger.  Check the wiring and connections to the sensor.  Replace Sensor.
 Code 22
Low Voltage
Check the adjustment of the TPS Plunger.  Check the wiring and connections to the sensor.
 Code 23†
Mixture Control
Solenoid
The Mixture Control Solenoid is Open or Grounded.
 Code 23
MAT Low Temp
Indication
Sets if the Manifold Air Temperature Sensor, Connections or Wires are Open for 3 Seconds.
 Code 24
Vehicle Speed Sensor
A Fault in this Circuit should be Indicated Only When the Vehicle is in Motion.
 Code 25
ATI Sensor/High Air
High Temperature Indication.
 Code 32†
BARO Circuit Low
Barometric Pressure Sensor Circuit Low.
 Code 32
EGR
Vacuum switch shorted to ground on startup, switch not closed after the ECM has commanded the EGR for a specific period of time or the EGR solenoid circuit is open for a specific period of time.  Replace EGR Valve.
 Code 33
MAP Sensor
Check the vacuum hoses from the MAP Sensor.  Check the Electrical connections at the ECM.  Replace MAP Sensor.
 Code 34
Vacuum Sensor or MAP Sensor
Sets when the signal voltage from the MAP sensor is too low.  Instead the ECM will substitute a fixed MAP Valve and use the TPS to control fuel delivery.  Replace MAP Sensor.
 Code 35†
ISC Valve
Idle Speed Control Error.  Replace the ISC.
 Code 35
IAC Valve
Idle Air Control Error.  Will set when closed throttle speed is 50 RPM above or below the correct idle speed for 30 seconds.  Replace IAC.
 Code 42
Electronic Spark Timing (EST)
Electronic Spark Timing bypass circuit or EST Circuit is grounded or open.  A malfunctioning HEI Module can cause this.
 Code 43
Electronic Spark Control
ESC retard signal has been on for too long or the system has (ESC) unit failed a functional check.
 Code 44
O2 Sensor Indicated Lean
Check the ECM Wiring Connections, particularly terminals 15 and 8.  Check for vacuum leakage at the TBI Base gasket, vacuum hoses or the intake manifold gasket.  Replace the Oxygen Sensor.
 Code 45
O2 Sensors Indicated Rich
Check the Evaporative Charcoal Canister and its components for the exhaust presence of fuel.  Replace the Oxygen Sensor.
 Code 51
PROM or MEM-CAL
Make sure that the PROM or MEM-CAL is properly installed in the ECM.  Replace the PROM or MEM-CAL.
 Code 52
CALPAK
Check the CALPAK to insure proper installation.  Replace the CALPAK.
 Code 53
System Over Voltage
(Alternator Problem)
Check Charging System
 Code 54†
Fuel Pump
Low Fuel Pump Voltage.  Sets when fuel pump voltage is less than 2 volts when reference pulses are being received.
 Code 54
M/C Solenoid
Check All Mixture Control Solenoids and ECM wires and connections.  The mixture control solenoid voltage is high at the ECM because of a shorted solenoid circuit and/or faulty ECM.
 Code 55
ECM
Be sure that the ECM ground connections are tight.  If they are, replace the ECM.
Old 10-01-2006, 08:36 PM   #8 (permalink)
Member # 30390
Apparently I really suck at searching, thanks a lot!!!
Old 10-01-2006, 09:34 PM   #9 (permalink)
Member # 5110
I figured that...lol. At times I think I have angered the google gods myself.
Old 10-02-2006, 10:41 AM   #10 (permalink)
Member # 64344
Quite a few sensors/senders feed into the ecm which will almost always set a code if something out of spec. is detected. Temp, O2, Knock, TPS, MAP - just to name a few. As far as the trans, sounds like a low fluid/plugged filter situation or worn bands. Also, make sure the TV cable is hooked up and adjusted properly.
1988 Chevy Suburban 4X4
1947 Willys CJ2A Jeep
My88TexasTruck is offline   Reply With Quote Quick reply to this message
