Chevy FAQ - Answers to common questions about your GM truck. - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-25-2009, 04:42 PM   #26 (permalink)
Member # 130473
A few years back I bought a 89 Chevy S-10 Blazer for $700 it was on a used car lot for $950 with a trashed windshield and a bent axle, and the fwd didn't work, the dummy that owned the lot had no idea what he had, I slapped a axle in, replaced the windshield, screwed a used vacuum switch into the transfer case and reconnected the hose under the battery. I then proceeded to find out just what I'd bought, so I buried it half way up the doors in mud, slapped the transfer case in 4 low put the trans in 1 and climbed out the drivers door window and watched the truck crawl out of the mud on her own.
Shes all stock, l except for the new radio I installed last year, and the general Grabber AT2 tires. Yes the old lady has a few problems, the window rubber is totally shot and she uses a quart of oil every now and then, but at 173892 miles she'll still stand up and smoke a Explorer off the line and through the whole range
The real fun part is when I pull a H2 out of the muck with a little 4.3 litre.
99.9% of my parts so are fome from a junk yard called pick and pull, Hopefully on here I can find more links like thease in this thread
wolfen1086 is offline   Reply With Quote
Old 03-30-2009, 04:27 AM   #27 (permalink)
Member # 127873
Wolfen1086 would the pick and pull where you are happen to be near Kansas City on I-435 because I have pulled many parts out of there over the past couple of years
MO4xer is offline   Reply With Quote
Old 03-30-2009, 11:02 AM   #28 (permalink)
Member # 132121
most of the info in this thread is gone
99z28monster is offline   Reply With Quote
Old 08-20-2009, 05:38 PM   #29 (permalink)
Banned
Member # 140863
http://www.tradeshoes9.com/product_read.aspx?pid=50302
tidyzhao is offline   Reply With Quote
Old 03-31-2010, 09:12 PM   #30 (permalink)
Member # 132080
anyone know where i can find a link to an exploded diagram for a dana 44 3/4 ton front axle? maybe a rebuild thread?
I found plenty of jeep ones and one for a scout II but neither had the hub assemblies, it was pretty much all diff stuff, and im not sure if it is the same as a chevy d44
Hardstripe is offline   Reply With Quote
Old 03-31-2010, 10:49 PM   #31 (permalink)
Member # 157094
not sure of a exploded diagram but what are you unsure of? i can explain how it goes together if you need
genebingaman is offline   Reply With Quote
Old 04-04-2010, 01:31 PM   #32 (permalink)
Member # 132080
Heres a great resource for the d44
http://www2.dana.com/pdf/5310-3.PDF
Old 04-11-2010, 04:50 PM   #33 (permalink)
Spy
TayJ's Avatar
Member # 106637
I would really like to see some more information added to this thread. Who can do that?
99 tj, kingpin 60 / 10.25, 42" rockers, project
99 yukon, motor done, tranny done, needing tons and tires and "which front axle is better with leaf spring" advice.
90 shadow 1100cc dd
TayJ is offline   Reply With Quote
Old 04-14-2010, 04:23 PM   #34 (permalink)
Member # 158316
does any one know what some good axles are for a solid axle swap in a 1995 Tahoe
Chevy Tahoe, all American power house
Honda accord racing 2FAST4U Jeep the kings of 4x4
wheeler4life is offline   Reply With Quote
Old 12-08-2010, 05:56 AM   #35 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
Gear ratio calculator
here is a link that has been mentioned a in the chev forum a few times to a very well put together gear ratio calculator that allows you to side by side different builds of your rig with different powertrain options: http://www.grimmjeeper.com/gears.html
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 12-08-2010, 06:01 AM   #36 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
U-joint identification
Here's some good links on how to identify different u-joints if you needed to:
http://www.therangerstation.com/Maga...08/ujoints.htm
this one is great for all the 1310 to 1400 series u-joints:
http://www.actionmachineinc.com/ujoi...ringguide.aspx
here's a couple found by member Guidolyons:
Cross reference Dana/Spicer u joint dimensions here:
http://www2.dana.com/expert/wc.dll?h...ookup~5-297-1X
Neapco has a good .pdf with cross reference to other mfg part numbers, too:
http://www.neapco.com/pdf/2007universaljointcatalog.pdf
http://www.pirate4x4.com/forum/showthread.php?t=933618
Old 12-08-2010, 09:57 PM   #37 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
welding tips
ok, whether you know how to weld, think you know how to weld but really you don't, or just plain don't know anything about welding but want to learn then check this guys website- he really knows his stuff. also, check out the video he has posted of the guy that can weld with two stick electrodes at the same time on the same pipe/opposite sides: http://www.weldingtipsandtricks.com
Old 01-06-2011, 07:02 AM   #38 (permalink)
90ctd's Avatar
Member # 110717
Location: Glen Burnie, MD wishin I was still wheelin in N Idaho
52/56/57/64" Spring Swap Thread
These are some of the more helpful threads I've found on swapping long spring onto you 73-87/91 chevy. Hope this helps those looking to do the swap.
http://pirate4x4.com/forum/showthread.php?t=881372
94 ZJ- 4.0- 5.13s-D60 lockright- D60 welded- 39.5 TSLs and H1s- 4:1 DEO Flipped dana 300 on the way
90ctd is offline   Reply With Quote
Old 01-22-2011, 03:07 PM   #39 (permalink)
Newbie
mikey81's Avatar
Member # 180430
Originally Posted by Juztyn00 View Post
Steering Arms
Steering Box - Info
How to rebuild it
How to Tap it for Hydro Assist
Steering Box Location
More pictures of mounting the power steering IFS boxes here:
Steering Column -
Storage -
Tailgate
TBI -
TBI intake to earlier engines-
/forum/chevy/512960-will-tbi-intake-bolt-up-early-80s-engine.html
Thermostat
Tie Rod Ends
Tow Hook
Chevy Vendors - Popular ones
http://www.12voltguy.com
http://www.advanceadapters.com
http://www.bluetorchfab.com
http://www.gotpropane.com
http://www.offroadsolutions.com
http://www.polyperformance.com
http://www.rockstomper.com
TRANSMISSION -
TOTW Shifty Characters:
http://www.pirate4x4.com/forum/showt...hreadid=119855
Identification:
Transfercases
Years Engine Model Shift Style Spline Type
GENERAL LIST OF Chevy TRANSFERCASES
COMPARISION INFO
TRANSFER CASE ASSEMBLY/DISASSEMBLY
FRONT WHEEL DRIVE
TWIN STICK with single forward shift t-case (on the cheap)
TRANSFER CASE PARKING / E-BRAKE
TRANSFER CASE MOUNT TECH
More Tranny & Transfercase Info
i want to know more on th taping of th steering box for hydr. ass. i have a 2wd 84 chevy one ton steering box ........ and what pitman arm to use for th cross over
sorry bout your bad luck, get her did.......
84' chevy 1 ton crewcab dana 60 14b 350 th400 np208
mikey81 is offline   Reply With Quote
Old 01-27-2011, 06:58 AM   #40 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
drivability problems, stalling, backfire, lack of power
here's a good website that lists common trouble areas and stuff to check when experiencing engine drivability problems such as backfiring, lack of power, hard starting, etc. it's mostly for carbureted vehicles but most stuff can be applied to all cars/trucks. http://www.recarbco.com/technical/newtrouble.html
Old 03-01-2011, 10:24 AM   #41 (permalink)
Member # 184633
Anyone know where all the actual information went from the first post of this thread?
PirateLowRider is offline   Reply With Quote
Old 04-05-2011, 09:59 PM   #42 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
rebuilding a 205
here's a good article on rebuilding a 205 as well as some of the differences in them. also search the first page of the chevy FAQ. Grumpy posted a good thread on the different adapters and input gear combos available for a 205.
http://www.4wheeloffroad.com/techart...ase/index.html
Old 04-13-2011, 04:02 AM   #43 (permalink)
Web Wheeler For Hire
Eagle-Mark's Avatar
Member # 26999
Help with converting or maintaining your fuel injection system. Wiring diagrams, starter chips, information on software and hardware to modifiy your EFI.
http://www.eagle-mark.com/Forums/
Addicted and Obsessed with Fuel Injecting Anything!
GearHead-EFI.com
Eagle-Mark is offline   Reply With Quote
Old 07-22-2011, 03:46 PM   #44 (permalink)
jblack6527's Avatar
Member # 100161
x2
Originally Posted by Thomas Jefferson View Post
"Those who surrender freedom for security will not have, nor do they deserve, either one." .
jblack6527 is offline   Reply With Quote
Old 11-07-2011, 05:28 AM   #45 (permalink)
Member # 201941
How do i tell the difference between a np208 and a np241 transfer case? I just bought a th400/np208 combo to put in my 93 4runner. The guy said it came out of a 90' suburban and he told me it was a 208 but from what i have been reading they came with either the 208 or the 241 so mybe he didn't know and just assumed it was a 208. Thanks
NWOleman is offline   Reply With Quote
Old 11-08-2011, 04:45 AM   #46 (permalink)
Member # 201941
Well it is a 208 by the tag but i would still like to know how to tell the difference between the 241 and the 208.
Old 11-08-2011, 07:50 AM   #47 (permalink)
Eagle-Mark's Avatar
Member # 26999
Google
http://www.high-impact.net/transmiss...case_NP241.htm
http://www.high-impact.net/transmiss...case_np208.htm
GearHead-EFI.com
Old 03-02-2012, 06:41 PM   #48 (permalink)
Member # 213123
i have a woods buggy with an vortect 350 in it. the sterring pump over heats and quits on me at times locking the sterring up what do i need to do to take care of this problem?
geno200 is offline   Reply With Quote
Old 03-02-2012, 06:50 PM   #49 (permalink)
Member # 213123
i have googled this and cant seem to find a solution. does anyone know what i might try to do to help this problem
Old 03-02-2012, 06:53 PM   #50 (permalink)
Member # 213123
no one seems to know what i might try to di with the sterring pump over heating on the 96 vortec motor with stock sterring pump....
