Discount!
SBC water pump ?
I have an older 327 (year unknown) I was attempting to swap out all the drive pulleys when I got to the water pump. The new 3 groove pully would not seat fully on the water pump. I seem to recall that there is a short and a long water pump available. Is this true? If thats the case I can just swap mine out for one correct? Thanks,
Jeff Fretwell 72 FJ40 67 FJ45 83 Toyota 4x4 LB |
Member # 65840
It sounds like what you have is a short water pump with long water pump pulleys. (If the pulley is bottoming out on body of the water pump)
If your crank pulley is cup shaped too, it sounds like you have pulleys for a long water pump set-up. The other problem you'll run into if your just trying to install long pump pulleys is the alternator / power stering brakets wont work either. If you look in a summit or jegs catalog, they make seperate brackets for short and long water pump applications.
It's probable that some of the afore stated are opinions. There is a reason they are free. |
short pump was last in 68 on cars except vettes,
and in 72 on light trucks(1 ton and under) huge difference between a short and long pump plain as day short pump is way smaller in size overall than a long pump would be very obvious if its a 327 and has a factory correct pump on it then it is still short swap a long pump on it off any later engine if you are going to swap later alternator and p/s onto it or find a short pump pulley if you are jut missing that only what do you have or what dont you have intact on the 327 ? is it driver side or pass side alternator ? if you dont have the original style p/s on it then youll have to find one for it to work right this stuff is all different than long pump stuff everything if you had pics we could help alot better than this good luck
Im parting 1980s 4x4 Toyotas & chevies 1960s-80s - cars too! text 2176717792 to get to me quick Last edited by Fast68; 10-28-2006 at 03:44 PM. |
Discount!
I pulled all the pulleys plus the power steering pump and brackets off a 78 Monte Carlo. Everything seems to fit fine except the water pump pulley, because it hits the pump housing. It seems that if I get a long style water pump, everything should work fine. My alt. is on the driver side, but looks like all I need to do is shorten and modify the adjusting bracket to make it work. Thanks for the help,
