14 bolt gearing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-30-2006, 10:21 PM   #1 (permalink)
Member # 81630
14 bolt gearing
i have a FF14bolt with a 4.10 in it can i put 4.56 gears in with either a locker or spool without changing the carrier
67mudhog is offline   Reply With Quote
Old 10-31-2006, 06:25 AM   #2 (permalink)
Member # 81574
Randy's R&P lists a yukon 4.56 thick gear set that fits the 4.10 carrier
HighRs is offline   Reply With Quote
Old 10-31-2006, 11:58 AM   #3 (permalink)
Member # 10366
The 4.10 carrier is actually the one to have if you ever want to go even lower. I bought a CUCV axle and the stock 4.56 gears/carrier are proving to be the only gears that will fit on that carrier. All the gear manufacturers make their 4.56, 4.88, 5.13, and 5.38 gear thick to fit the 4.10 carrier. So I'm pretty much screwed. Wish I had known this before I bought these axles.
Travis
MOGXJ44 is offline   Reply With Quote
Old 10-31-2006, 04:06 PM   #4 (permalink)
Member # 81630
thanks...so it wont matter if i put a detroit in or not still gonna need the thick gears i guess
Old 10-31-2006, 04:15 PM   #5 (permalink)
Member # 21453
As the others said....unless you got a 4.56 carrier already most aftermarket gearsets are designed to fit the 4.10 carrier.
However, its said (and i dont know if there is any truth to it) that the thick 4.56+ gearsets are marginally stronger. Anyone know if there is any truth to this?
Kilborg is offline   Reply With Quote
