BBC vs. SBC - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-09-2006, 01:26 PM   #1 (permalink)
Member # 47273
BBC vs. SBC
I have a 383 stroker motor and I have a 468 BB. My question is not which one to use, I know I want the BB! My question is does anyone have any solid facts on both motors? Not hp/torque ratings but size and weights. I want to make sure the BB is going to fit in the buggy before I start tearing everything out.
krazytoy is offline   Reply With Quote Quick reply to this message
Old 11-09-2006, 01:52 PM   #2 (permalink)
Member # 17568
Well I have numbers to help you, they are close enough.
BBC 700lbs
SBC 400lbs
imiceman44 is offline   Reply With Quote Quick reply to this message
Old 11-09-2006, 01:56 PM   #3 (permalink)
Member # 47273
Holy crap almost double the weight! Damn the buggy was almost balanced! How about length and width comparisions, those would help too. Thanks
Old 11-09-2006, 03:24 PM   #4 (permalink)
b454rat's Avatar
Member # 16536
I think they both weigh more than that. A BBC is about 2" taller, wider and longer than a SBC. If you can put a BBC in an S-10, then you can put it anywhere. If you get alum heads, intake and water pump, it weighs what a SBC weighs. I had a SBC in my 78 Malibu, then put a 468 with all alum stuff, and other than the power increase, didnt ride any different.
1999 GMC CCSB plans for 8.1 and SAS
b454rat is offline   Reply With Quote Quick reply to this message
Old 11-09-2006, 03:37 PM   #5 (permalink)
Member # 47273
I found some info here on weights.
http://www.bacomatic.org/~dw/txt/engfyi.htm
According to this only bout a 100# difference?
Old 11-09-2006, 04:24 PM   #6 (permalink)
Member # 67473
small blocks way stock 573 pounds and big blocks are about 650
chris walker is offline   Reply With Quote Quick reply to this message
