14 bolt-disk brake-parking brake? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-10-2006, 06:12 AM   #1 (permalink)
Member # 27377
Has anyone ever swapped out the stock drums for disks with a parking brake? Any tips on this would be greatly appreciated.
I read that cadillac calipers may work, but no sure about the rotors and brackets.
78 Blazer, Dana 60/14bolt, crossover steer, front and rear ARB's, beadlocked 39.5 Irok's, 465/205, smallblock 400, TBI.
"...........and that was without a single drop of rum!"- Captain Jack Sparrow
Badburn is offline   Reply With Quote
Old 11-10-2006, 06:30 AM   #2 (permalink)
Member # 42026
Use the same brackets as any other 14 bolt disk brake conversion and get Eldorado Calipers for the rear of a 76-78 and they will fit. For rotors just get 73-87 3/4 ton front rotors. I have that setup but have never hooked up the cables. I have jacked up the rear end, let it turn about 20, and used vice grips to move the arms and it seems to stop the wheels ok. A lot of people don't like them.
maddog411 is offline   Reply With Quote
Old 11-10-2006, 06:53 AM   #3 (permalink)
Member # 27377
They dont like the calipers? why?
Any idea where to get cables?
Thanks.
Old 11-10-2006, 09:09 AM   #4 (permalink)
Member # 343
They don't like the calipers because the do not stay adjusted. The E-brake must be used often to keep them in adj. They stay in adj on mine with freq. use of the E-brake.
cj8scrambld is offline   Reply With Quote
Old 11-10-2006, 09:11 AM   #5 (permalink)
American's Avatar
Member # 12257
Send a message via AIM to American
Who would spend the extra dough on an e-brake that wasn't going to use it often? 'tards
EB Truggy on 39.5's - FOR SALE $6,000 obo
TopOffroaders buggy by CBfabwerks: in the works
5.3, th400, np205, hp60, 10.5", 18" CO's, 43's, H1's
American is online now   Reply With Quote
Old 11-10-2006, 10:24 AM   #6 (permalink)
Member # 343
OK OK, you're right I didn't mean "often"....I meant all the time.
Old 11-10-2006, 11:53 AM   #7 (permalink)
Member # 48424
Some states require parking brakes to pass inspections - something that is a must for DD's.
But I don't run them.
I Love Grits is offline   Reply With Quote
Old 11-10-2006, 12:15 PM   #8 (permalink)
Member # 42026
Thanks.
As mentioned, the calipers require use of the parking brake to stay in adjustment. They do not self adjust like other disk brake calipers. When you get them be sure to turn the arm and let them adjust before you ever use the hydraulic brakes. You should use the parking brake or turn the arm at least once a week after that. You could probably use your stock ebrake cables, but the trick is making a mount/fixed point near the end of the cable to replace where the drum brake backing plate normally holds it.
Old 11-11-2006, 12:57 AM   #9 (permalink)
Member # 57140
Send a message via Yahoo to rockcrawler80
Chris over at Rock Tech carries a hydraulic locking valve that"ll lock up the brakes. (562) 690-8321 This will eliminate the E-Brake cable from getting cought on the trails.
[B][/B][FONT="Arial Black"][SIZE="4"][COLOR="Yellow"][B]FKM[/B][/COLOR][/SIZE][/FONT]
rockcrawler80 is offline   Reply With Quote
Old 11-11-2006, 08:20 AM   #10 (permalink)
Member # 15404
Is this any different than a line lock? You can get those anyware but if you are trying to pass an inspection most I have seen require a mechanical e-brake system....
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
Old 11-11-2006, 06:00 PM   #11 (permalink)
Member # 80154
i would recommend a parking brake. i never used to run them and one time i was doin a hill climb and broke my spring perches and spung the axle around ripping out all brake lines and leaving me rollin backwards. i threw it in gear, but its just a suggestion.
norcalsasgmc is offline   Reply With Quote
Old 11-12-2006, 06:15 PM   #12 (permalink)
cbbr's Avatar
Member # 34555
Hundreds of people have done in. Many bitch about it. Look at http://www.tsmmfg.com/Rear_Disc_Brake_Kits.htm
Run when you can, walk if you have to, crawl if you must; never give up.
cbbr is offline   Reply With Quote
