Banned
Member # 24704
It won't fit your transmission, so that will be the first batch of problems.
After that, the motor mounts won't line up, either. For all the bullshit to put in a 165 HP 4.3, I'd definitely look into what it takes to swap in a V8--because both are equally difficult. |
tell your friend that 4.3L and up except rear wheel drive 3.8L are 90 degree and that the 2.8L and such small engines are 60 degree
nothing interchanges, bolts patterns all different, intakes different widths good luck
Im parting 1980s 4x4 Toyotas & chevies 1960s-80s - cars too! text 2176717792 to get to me quick |
Member # 20423
Unless you are actually only talking about the 4.3- 1 11/16" TB to replace the 2.8- 1 3/8" bore.
But then the holes in the manifold are still small and the inj are now bigger so it will be pig rich more then likely. Your mileage will take a dive and it will probably run like crap till you burn a new chip for it to tune the fuel tables. When your all done it might make a little more power but that would be more from the tuning then the TB!!
Bill USN-1 EFI Moderator at http://www.binderplanet.com |
Member # 82514
tbi
The injectors are interchangeable you will probably need new o-rings it is a simple change as far as how much power I dont know I got this link from bill usn1 (thanks bill) I'm gonna try and post a link you might have to type it in yourself its to a page on how to take them out and how to adjust the fuel pressure on you tbi
http://www.binderbulletin.org/forums...293#post298293 if you want more hp for free a taller air filter try a 90 dodge van w/5.2 318 the timing can be advanced a liitle bypass or plug some of your vacum lines do this one line at a time so if you un hooked something you shouldn't have you can change it back if you have a manual tranny you can bypass you vacum canister (not to be confued with the charcol canister) it you have a auto you need it for your tranny to shift right if you still cant get enough power put a 350 LT1 in it good luck
Put your seat belt on and watch this! Last edited by wreckincars; 11-21-2006 at 03:22 PM. |
Wannabe
Member # 3235
Another option would be to swap in a 3.4L motor instead. It bolts directly in place of the 2.8 (same tranny, same accessories, etc). GM sells a crate version specifically for this purpose.
http://www.sdpc2000.com/catalog/3507...e-Assembly.htm If converting the truck to V8 power is too much work then I'd go that route (or rebuild what you've got).
Jon B. '82 CJ7 some mods. There is no replacement for displacement! |
i have a link for you, its a how to artical for swaping the 2.8 for the 4.3, and its pretty good, site is down at the moment, but should be up in a lil.
[QUOTE=Sturgell;7838459]Hell yes it does. Going balls deep in some chicks bellybutton should be a requirement of all men.[/QUOTE] I'll stop Web Wheelin' when i get tires! post 46 in the biggest thread backfire of the year :flipoff2: [email]XxStirCrazedxX@Gmail.com[/email] |
ok its still down, but heres the link
Link
[QUOTE=Sturgell;7838459]Hell yes it does. Going balls deep in some chicks bellybutton should be a requirement of all men.[/QUOTE] I'll stop Web Wheelin' when i get tires! post 46 in the biggest thread backfire of the year :flipoff2: [email]XxStirCrazedxX@Gmail.com[/email] Last edited by XxStirCrazedxX; 11-22-2006 at 06:49 PM. |
Member # 33482
Check out S10-extremists. Look for an article in teh Tech Section (top left side of the page). They cover the 2.8L options pretty well.
Here's teh link, and it works. http://www.s10extremist.org/forums/ Here's the link to the tech article. http://www.s10extremist.org/tech_art...28to34swap.htm
blah blah blah...... Last edited by Hanr3; 11-23-2006 at 04:14 AM. |
