disk brake help please - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-25-2006, 04:25 PM   #1 (permalink)
Member # 67900
Send a message via AIM to Big$exyBlazer
Alrite i am doing the 14 bolt swap and also did the disk brakes, i used my stock brake lines hooked up to softlines going to the caliper, the thing is i cant get fluid through, any ideas? do i needa change the stock line or maybe the banjo bolt aint linin up right? i need help guys
Go Big or Go Home
If ya cant run with the big dogs stay on the porch
1987 blazer, 350, 700r4, factory running gear, looking for dana 60 for front if any one has 1, i have 14 bolt for back, 12 inch suspension, 44 ground hawg's
Big$exyBlazer is offline   Reply With Quote
Old 11-25-2006, 04:37 PM   #2 (permalink)
cbbr's Avatar
Member # 34555
What kind of softlines?
Run when you can, walk if you have to, crawl if you must; never give up.
cbbr is offline   Reply With Quote
Old 11-25-2006, 04:59 PM   #3 (permalink)
Member # 67900
soft lines that came stock on a 75 3/4 ton
Go Big or Go Home
Old 11-25-2006, 05:36 PM   #4 (permalink)
mj
Member # 1919
prop valve has a button that has to be pushed or pulled
mj is offline   Reply With Quote
Old 11-25-2006, 06:08 PM   #5 (permalink)
Member # 67900
what do you mean?
Go Big or Go Home
Old 11-25-2006, 06:52 PM   #6 (permalink)
bigyellowjimmy's Avatar
Member # 53682
do you have a vac bleeder? You prolly have air that pumping the pedal isnt pushing out
Freedom is only part of the story and half the truth….That is why I recommend that the Statue of Liberty on the East Coast be supplanted by a Statue of Responsibility on the West Coast.
Viktor E. Frankl
bigyellowjimmy is offline   Reply With Quote
Old 11-25-2006, 07:01 PM   #7 (permalink)
Member # 67900
i just unhooked my flexible brake line from my stock line and no fluid is comin out, what to do now?
Go Big or Go Home
Old 11-25-2006, 07:25 PM   #8 (permalink)
Member # 53682
do you have a vac bleeder??
Viktor E. Frankl
Old 11-25-2006, 07:34 PM   #9 (permalink)
Member # 67900
No i dont where can i get one? do you think this is what i need?
Go Big or Go Home
Old 11-25-2006, 09:01 PM   #10 (permalink)
Member # 43029
Local auto parts store has a vac bleeder.. also if the factory proportional valve tripped I have had good luck with my buddy pumping the breaks while i tap the valve and it releases the lock out to the rear line and bam you got fluid going back there..takes a little bit but it worked for me 3 times.
suburban N progress is offline   Reply With Quote
Old 11-26-2006, 08:00 AM   #11 (permalink)
Member # 53682
like suburban said, you can pick one up at any parts store for $30-40, you can bleed your brakes by creating a vacuum and forcing the fluid past the air lock. If you put a vac on it and it doesnt suck the fluid down in the MC you'll need to investigate the PV having an air lock like has been mentioned.
good luck
Viktor E. Frankl
Old 11-26-2006, 07:33 PM   #12 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
ont ht eend of the prop valve is a small black rubber cap, push it and pump the pedal, push it and pump the pedal, it will flow, just be paiteint and keep pumping
trkklr77 is online now   Reply With Quote
Old 12-02-2006, 11:28 AM   #13 (permalink)
Member # 4746
What do you guys do about the proportioning valve when swapping to disc brakes on a 14 bolt? Do you remove the check valve or is it fine to leave the proportioning valve alone? Thanks, Mike
86 SB Chevy Big Block D60 FF14 Detroits 38.5"Boggers
01 Wrangler 4"lift D44 4.56 Auburn ECTED 35's
cj7mb is offline   Reply With Quote
Old 12-02-2006, 03:01 PM   #14 (permalink)
Member # 43029
I left mine alone and never had any problems..never once did i lock my rear on wet roads and bring the ass around..worked great..but that was me though..i dont know if anyone else had same success
Old 12-02-2006, 06:34 PM   #15 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i left the prop on and i can slide my rear if i want to in the wet, but the work great all the time, if you really stomp on them theyll lock but i havent had them un-expectedly lock in a emergency stop.
