Member # 67282
Increasing 6.2 power.
I have done alot of research on how to increase power in my 85 GM 6.2 diesel. Turbo, maybe dual turbos, propane, possibly nitrous, maybe computer programs. . . but is it possible to bore the 6.2 to perhaps a 6.6? would that put the block at risk of cracking? is it even possible with a diesel? any info pros and cons would be greatly appreciated.
Member # 52752
those engines have a bad enough rap with heat and you want to bore it? Your problems will be... never try to get displacement from boring, it comes from the stoke and i am certain no one make a stroker crank for a 6.2. HEAT HEAT HEAT. even if you bore it and get pistons that work you will never get even close to 6.6l. that would be approx like adding about 25ci which equates to drilled water passages.
I don't want to sound like a total sour puss, but the stroking idea just isn't going to be worth the effort. |
Member # 67907
Check out www.dieselplace.com
I think there is something in swapping a 6.5 crank? If it were mine, I would crank the pump all the way up, let the engine melt, then swap in a bbc
The Beepster [url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url] Last edited by Jeepermat; 11-27-2006 at 09:22 PM. |
Member # 613
put a turbo on it, set of boost and pyro gauges and go with it. If you do bore use a set of low compression pistons with the turbo maybe add a intercooler. The 6.5 crank won't gain you anything same stroke just a different seal design that won't work with early block. Might find a race shop or really good machine shop to index grind the crank to get max stroke out of it. The heat issues can be dealt with using common parts now out.
Member # 52752
www.ssdieselsupply.com deals with the 6.5 and i think they have some stuff for a 6.2 also, worth a shot
lets go Squatchen
Member # 14561
You can bore the block to 6.5l and use 6.5 pistons and rings but it's not really worth the expense.
What vehicle is this in, what is the 8th digit of your vin, and what is the purpose of the vehicle (tow or off roading)? The J code 6.2s had a different intake design and developed more power, basically the HD version of the engine. If you don't have a J code engine you can still find and use the intakes. Consider getting an all gear timing set up. Get a high flow H20 pump. Use the correct thermostat, do a google for Kennedy Diesel and give them a call for the pump and t-stat. Turn up the fuel about 1/8-1/4 turn on the IP. Advance the timing about 1/4" past the timing mark. Open up your intake and exhaust. If you are not going to go turbo you can get headers for the 6.2, but they run $400. If you have access to a water jet or CNC plasma and can get manifold plates cut you can get some chevy big block headers, cut off the plate, and weld the pipes to your new plate. The exhasut ports are like 1/4-1/2" off between the engine (get a set of exhaust gaskets from a 454 and 6.2 and compare ) Port the exhaust and flange to match. Wrap the headers and use dual 3" pipes. Get the heat away from the engine.Get the J code intake, and then modify the airfilter housing by adding a second air trumpet. Cut the trumpets so they have a 3" opening and then use some flex hose to plumb them both to fresh air. Install an egt gauge. Doing all this you can build a 6.2 to put out 200hp and 300ftlbs of torque with out going turbo. Next up in the power output would be to Get some 6.5 heads, 6.5 high pop injectors, and a 6.5 mechanical IP (think its the 6911) If this isn't good enough for you call banks and get their turbo. Get an intercooler. Get a boost gage. If you know in advance you are definately getting a turbo get the low compression ceramic pistons. After this, second Banks, so you can have a twin turbo. Loose the cross over and modify the banks exhaust to work on the other side. Propane injection, this lowers EGTs.
Want to know how I lost 25lbs in 9 weeks? Try INSANITYŽ. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
Member # 4243
The #599 block can be bored to 6.5L displacement. I would add a basic turbo kit (or use stock 6.5TD stuff). Redo the pump for the turbo. Maybe a propane kit. Gear drive cam also.
The way I see it, the 6.5TD maxed out the 6.2L engine design. If you need more jam that that, start with a completely different engine.
90-93 CTD jalopies |
#9 (permalink) | |
Member # 67907
X2
The Beepster [url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url] |
Member # 21453
The 6.2 was a pretty good mill...gutless stock, but ran forever provided you knew the quirks.
There was a guy who put some big bucks into one and ended up with making around 250rwhp...i believe he was on the 6.2/6.5 page that may give you some ideas. The easiest way to get to around 200hp is the banks turbo...wont make it a tire shredder but what a difference over the stock n/a motors. |
#11 (permalink) | |
Member # 64748
I caught your Jeep thing now it BURNS when I piss! |
#12 (permalink) |
Member # 45481
The biggest improvement I made to my 6.2 was getting it in front of a sm 465! I went from hating it to loving it with a tranny swap, the th400 is a power sucking Mfer. My J-code 6.2 finds its power band much easier with the 4spd., hell a nv4500 would even be better!
Leave it stock or be prepared to sweep it up. my.02
Support Yellow Star Members /forum/general-4x4-discussion/688801-yellow-star-vendors-list.html Aerospace Tool&Die by trade..Don't call me a machinist! Currently enduring the mother of all affirmative action hires! Stalled FJbuggy project .. Red XP ! WCP Lover! |
#13 (permalink) |
Member # 42843
if heat is a real problem, then turbo will add a lot of heat. all that compressed air gets HOT quick.
and don't worry about twin turbos... they are more or less old-hat, what with new turbo technology and turbos bigger than a bowling ball. besides, they are a PITA to synchronize (i mean it would cost a shit load). normally i'm a BIGGGG proponent of forced induction, so turbo is my vote. but not until you address how you are going to get more fuel to go with all that new air. and, if people say heat is a problem... maybe you should look at a 4-core rad with a lower thermostat temp too. |
#14 (permalink) | |
Member # 35786
#15 (permalink) |
Member # 67282
All very incredible advice. Much, if not all, of which will be put to use. Somebody talk to me about nitrous in addition to propane, and a supercharger in addition to turbocharger/twin turbos. I understand the expense of what im talking about, but lets have this discussion in the ''unlimited funds'' mindset.
#16 (permalink) | |
Member # 17568
Propane helps the diesel fuel burn more efficiently. Supercharging is a good way to get the boost up from idle unlike turbo which need some RPM's to start spooling. You can use Turbo+Propane+nitrous or Supercharger+propane+nitrous I don't know if I would use a turbo and supercharger together although I heard someone did.
IceMan selling everything :( |
#17 (permalink) |
one of my friends runs a cucv . he recently added the 6.5 intake and turbo, and messed with his pump and it is a completely different rig. i know thats the typical red neck story , my buddys got this or that but hes not on this forum . just giving my .02 . that bolt on definelty helped the ol 6.2
later ryan
396 forged and rollerd' [U]small block[/U], propane, 60 /14 with chromos ,th400, ord doubler , HAD 1410s f/r , full hydro, lockd 42 sxs .... all wrapped up in a glittery package 07 d max LBZ with a fatgirl on the back |
#18 (permalink) |
The last time I talked to a sales rep over at Banks, they told me that they no longer make their Sidewinder turbo kits for the naturally aspirated diesels. However, that doesn't mean you can't find a used kit for sale on eBay or somewhere like that. One thing I have noticed on dieselplace.com is that people are making their own turbo kits using parts from the 6.5TD engine. I'm not sure if ATS still makes their turbo kit for the 6.2 either.
Scott
[URL="http://facebook.com/tenbucks76"]http://facebook.com/tenbucks76[/URL] |
#19 (permalink) | |
Member # 67282
As a side note, if i wanted to look for a supercharger for the 6.2, where would i find one? who makes them? Last edited by stantjeeper85; 11-29-2006 at 09:46 AM. |
#20 (permalink) | |
Scott
