Snorkel Ideas - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-02-2006, 07:21 AM   #1 (permalink)
Member # 30045
Snorkel Ideas
What are you guys doing for snorkels on carb'd and tbi V8's?
[url]http://omghi2.us/[/url]
ascaps is offline   Reply With Quote
Old 12-02-2006, 10:42 AM   #2 (permalink)
Member # 73492
I have seen people use one for a land cruiser. They just heated the corner up and bent it more. Or there is always PVC!!!
88 Sub, 6" Lift 44F,14R Olive drab, 37" Military OZ's On Stazworks H1's
widmayer123 is offline   Reply With Quote
Old 12-02-2006, 10:50 AM   #3 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i just found the perfect starting point at pepboys.
the chrome company, spectra, that make all the cover, cleaners, and random chrome shit in the black packages, is now makeing a carb hat of polished aluminum that is intended for the cone aircleaner kits. it has a carb base and a 4" 90* inlet for $70 or a dual one is $90 with a 110* spread.
they are $$$ but a very very good start and are a decent thickness.
Old 12-02-2006, 09:42 PM   #4 (permalink)
Member # 30045
That sounds ideal, but there are no Pep Boys around here. I'll have to go check out what Advance Auto has.
Old 12-02-2006, 09:54 PM   #5 (permalink)
Beaver Pleaser
florida4x4's Avatar
Member # 13645
home made stuff
1972 GMC Submarine
383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez
Inclined to brute force attack a 70* incline with a Quadrajet
1997 GMC K3500 Suburban
Turbo 5.3 in the works / 4L80E / HP60 SAS / PROJECT TOWHOE
florida4x4 is offline   Reply With Quote
Old 12-03-2006, 12:46 AM   #6 (permalink)
Member # 30045
Originally Posted by florida4x4
home made stuff
That's cool stuff. I like that idea because it seems relatively cheap.
Is that tubing that you used for the main body, or did you just bend sheet metal?
Old 12-03-2006, 11:03 AM   #7 (permalink)
Beaver Pleaser
florida4x4's Avatar
Member # 13645
had to roll the carb hat from sheet because it's something like 5 1/4" dia. then used 4" tubing and more sheet metal for the snorkle and splash guard.
1972 GMC Submarine
Old 12-03-2006, 11:09 AM   #8 (permalink)
Member # 3721
Send a message via MSN to jr4x4ee
Here is my stainless steel snorkel on 6.2D. Outer diameter 110mm.
PVC pipe looks cheap and remainds the toilet, so that is no go.
Greetings from Estonia
Jaak
jr4x4ee is offline   Reply With Quote
Old 12-03-2006, 11:59 AM   #9 (permalink)
Member # 30045
Do you run a cone filter on the end of that, or are you not worried about having a filter because it's inside the cab?
S10 guys: Do any of you have a snorkel running through the firewall while still having the stock heater box? Am I alone here?
Thanks for all the pics and ideas so far
Old 12-03-2006, 11:59 AM   #10 (permalink)
jarvisjeep's Avatar
Member # 55381
Send a message via AIM to jarvisjeep Send a message via Yahoo to jarvisjeep
Jr4x4ee, That snorkel looks very functional. Do you have an aircleaner on the end of that? Or just one inside?
[COLOR="Lime"][CENTER]4x4 limo guy
[URL="http://www.liftedlimo.com"]
http://www.liftedlimo.com[/URL][/COLOR][/center]
jarvisjeep is offline   Reply With Quote
Old 12-03-2006, 01:46 PM   #11 (permalink)
Member # 3721
Just one under the hood. Green Monster Twister.
Just ends behind the cabin. Has a small net inside, to prevent flying debry to enter the snorkel.
Jaak
Old 12-03-2006, 03:53 PM   #12 (permalink)
Member # 30045
Looks nice and seems like it works. Aren't you worried about it getting smashed by tree branches and other trail hazards?
Old 12-03-2006, 04:04 PM   #13 (permalink)
Beaver Pleaser
florida4x4's Avatar
Member # 13645
I hava k&n on the inside.
jr4x4ee, all that SS looks crazy expensive!! you work at the factory or something?
1972 GMC Submarine
Old 12-03-2006, 04:06 PM   #14 (permalink)
Member # 3721
Its tough enough to take beating from tree branches. Well connected to the body and if I smash it then hey, I can get to build better one.
Jaak
Old 12-03-2006, 04:10 PM   #15 (permalink)
Member # 30045
I like that outlook on things
