welding spider gears
Can you weld the spider gears in a gov-loc 14 bolt ff?
1991 K1500, straight axle conversion, 39.5-18-16.5 Boogers! Warmed up 350 small block, turbo 350 trans, Dana 60 front, 14 bolt rear 4:56 gears, and a 175 shot of the laughing gas! |
You'd have to totally remove the locker, and even then I'm not sure. The only reason I'm replying is because about two weeks ago we popped my diff open and found a govloc. There was no way it could be welded without pulling out of the housing so we just put it back together. I'm going to give it a shot and see how it works. At the time we openned it the truck had never been offroad.
-Jay |
well I tryed it on mine and it is making all kinds of noise now and I think I broke something. does anyone have a wright up on how to this if it can be done
I welded mine up, after asking the same question here. Just remove everything that is part of the locker, clutches, springs, that little gear/lever thing. Then it's as simple as welding an open diff but has 3 posts instead of 4.
[QUOTE=papee]This game IS real life for us web wheelers.:flipoff2: [/QUOTE] |
#5 (permalink) | |
Member # 15404
Life begins where the pavement ends! |
Member # 43812
Mine has been welded for 4 years now. i wheel 3 weekends a mouth (hard weekends too)
I just took out the disc and springs and welded the up the three grears. that easy. TBI 350 350 turbo 203 14bolt dana 60 4:11 38x12.5x15 AKA Critter
pulled mine back apart only to find the spider gears had exsploaded! so I welded the side gears to the carrier. I have an extra carrier so if this fails guess I will have to try again.
Member # 65726
If you trashed your carrier you may want to look at the 14b spool. You have a lot of weight and sounds like HP. Not to say a properly welded 14 b is not strong enough. There is threads on how to do it with pictures. The best way is pull the carrier out and weld it out of the axle. I welded mine, and run the piss out of it. Works great.
Isn't that the only way to do it? I have no clue how you would go about welding a 14ff, open or govlock, with the carrier still in the axle. Just weld and weld, throw some metal in and weld that, then weld some more. If you make the whole thing a ball of metal and can weld worth a crap, it should hold.
where is the best place to get a spool for the 14 bolt? I have broke two sets of spider gears. I am thinkin the 40's and nos seem to be alittle much for a welded carrier.
