Rockwell brake help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-14-2006, 11:04 AM   #1 (permalink)
Member # 54046
Send a message via AIM to BigF250on44s
Rockwell brake help
Ok so I'll be using the O.E.M hub/brake asembly on my rocks and wondered what u guys reccomend for MC/Booster combo? I'll also have pinion brakes but those will be my emergency brakes and be cable activated. Should I just switch to a 1ton MC/Booster or should I jump over to hydroboost. If I should go hydroboost what PS pump should I get? One from PSC?
'79 K10: 700whp 454, Built TH400, NP200, 2.5 Ton Rocks w/ USA6X6 2.5 Ton Brakes, 1 Ton MC/Booster, Driveline E-Brakes, Hydro-Assist High-Steer, 47" LTBs or 44" Boggers
BigF250on44s is offline   Reply With Quote
Old 12-14-2006, 04:26 PM   #2 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
If you already have pinion brakes why mess with the heavy drum brakes ? The pinion brakes will stop it just fine
97 tj 6.0 nv4500 241c on tons in the works
4doorchevy is offline   Reply With Quote
Old 12-14-2006, 05:01 PM   #3 (permalink)
Member # 54046
They won't stop shit. The truck will be driven at almost 70mph. I don't think pinions will do anything
Old 12-14-2006, 08:18 PM   #4 (permalink)
OCX Off Road Audio
TAWL_BOY's Avatar
Member # 72810
He means OEM as in Oueverson Engineering. With Disks.
But I normally hear people say the pinion brakes are too grippy. The main complaint is that they can get really hot or if you break a shaft=no brakes.
Custom Speaker Cans for Your Buggy, Side by Side, or Boat
LIKE US
Use PBB15 for $15 OFF Order of $130+
TAWL_BOY is offline   Reply With Quote
Old 12-14-2006, 08:41 PM   #5 (permalink)
Member # 41764
You realize the fact that the brake is on the pinion multiples the braking force by 6.72 times in a rockwell diff? The downside is the rotor then has to dissapate all that energy turned to heat quickly and they just aren't big enough to do that from high speed regurlarly.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
JasonPayneMemorial
bggrnchvy is offline   Reply With Quote
Old 12-14-2006, 09:36 PM   #6 (permalink)
Member # 79745
Man this guy don't think a lot of his truck
funny name for your truck
s10 truggy is offline   Reply With Quote
Old 12-14-2006, 09:42 PM   #7 (permalink)
HOT_DAMN's Avatar
Member # 66873
Your pinion brake should still work even if you have a broken shaft.
HOT_DAMN is offline   Reply With Quote
Old 12-14-2006, 09:51 PM   #8 (permalink)
OCX Off Road Audio
TAWL_BOY's Avatar
Member # 72810
What about with an open diff?
Oh and if you have unlocked selectable hubs, it's useless.
LIKE US
