Loose D44 Wheel Bearing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-11-2002, 07:45 PM   #1 (permalink)
Member # 1323
hey chevy dudes,
yes i know i belong on the jeep page but bear with me.....
i have a dana 44 from a 1976 K5 Blazer under my CJ full width. the axle has very few miles on it since rebuild but several years have past. there is a bunch of play in the bearing when i wiggle the wheel/tire. i assume the bearing is just loose. what size bearing nut socket do i need to tighten it and what is the torque spec??? i have a big ass prong socket for my rear D70, any chance its the same for the D44?? one other thing is it best to lock the hub before taking it out or leave it in the free position.
thanks in advance for any tips so i dont spend all mothers day up to my elbows in axle grease!!!!!
mike
1TonJeep is offline   Reply With Quote
Old 05-11-2002, 09:50 PM   #2 (permalink)
Member # 4737
It's a special socket that any parts house should have. What I've always done is torque the inner nut to 80 lbs to seat the bearing then back it off then tighten it up hand tight. put the lock ring in the torque the second nut to 80 lbs.
P.S. and dana 44 in the front doesn't make for a one ton heep.
1989 Chevy Blazer 350 V8
4x4realm is offline   Reply With Quote
Old 05-11-2002, 11:25 PM   #3 (permalink)
Member # 2643
A 1 ton 44 HUH? Is that like a 1/2 ton bulldozer.
1985 TOY TRUCK, FULL BLOWN CHEVY 350 V8, DUAL 4 BRL EDELBROCKS ON A 6-71 WEIAND. RUNNING ON METHANE. 625+ HP. REAR DANA 70 WITH DISK BRAKES, 60 FRONT, WELDED & LOCKED, 44"BOGGERS, FULL HYDRAULIC STEERING, RADIATOR IN BED, TILT FRONTEND, W9000I ( YES IT IS BUILT MOSTLY FOR ROCKCRAWLING, WITH A LITTLE EXTRA HP ). www.4x4realm.com
TEAM X-TREME is offline   Reply With Quote
Old 05-12-2002, 06:27 AM   #4 (permalink)
Member # 1323
ok, cut me some slack
the 44 is 3/4 ton, 8 lug and is only there till i can finish the 60 that will take its place or until it all i need is a detroit and 35 spline stubs and the 60 will be done, unfortunetly the detroit is $500+. i would love to sell the 44 complete and finish the 60 but i don't want to be without a rig for an extended period of time. know anyone looking for a 44 full width, 8 lug, new brakes, detroit, 5.13??? be part of the solution besides at least its not a 10 or 12 bolt ooops! did i say that on the chevy page!!!!
Old 05-12-2002, 08:52 AM   #5 (permalink)
Member # 1792
Actually the 10 bolt and D44 are the same in strength.And there is no 12 bolt fronts. Anyway Chiltons says to torque the inner nut to 50 ft.lb then loosen it and retorque to 35 ft.lb. Then back it off 3/8 turn or less.Turn the nut to the nearest hole in the lock washer and install the outer nut and torque to 50 ft.lb for through 78.Which is when the 10 bolts started coming in so that should work.Blazin
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers.
Cheepin is offline   Reply With Quote
Old 01-13-2004, 11:58 AM   #6 (permalink)
adz
Member # 12843
Which type of socket does the spindle nut require on the Chevy D44; 4 or 6 prong? I'm gonna go buy one today, but I haven't opened up the hub yet.
'73 K5 6.0L
'07 GMC Sierra 1500 4x4
adz is offline   Reply With Quote
Old 01-13-2004, 12:12 PM   #7 (permalink)
Member # 3694
Take a 4 prong socket about 10-15 bucks at parts store....good luck
Need Steering? www.shakerbuilt.com
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote
