Member # 84477
4x4 clunking
ok when i put my truck in 4wheel drive i can hear clunking like somings banging together.. all the u joints on the front drive shaft are new so i know its not that.. what else could it be?
.........605Motorsports....... |
Member # 53682
unless you can give a more detailed explaination of where the clunck is coming from (ie: hubs, d shaft, t case, etc) all you are going to get is guesses.
Freedom is only part of the story and half the truth….That is why I recommend that the Statue of Liberty on the East Coast be supplanted by a Statue of Responsibility on the West Coast. Viktor E. Frankl |
Member # 53682
when you lay on the ground looking at the components while an assistant slowly drives it what do you see/hear??
when you remove the front d shaft does the noise go away??
Member # 51243
Make sure your exhaust header/manifold/pipe isn't hitting your front driveshaft.
Mine is about 1/4 inch away Also, need more info. Chances are what you are hearing is the CV joint fixing to shit the bed. Have fun with that. lol
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#9 (permalink) | |
Member # 48607
Had to have my exhaust changed when i put my lift in. Noticed the other day that i had this terrible clunking sound as well. My dumb ass just thought it was the 205. Turns out my cv front shaft wobbles like a bastard. Also, the exhaust tube i had made to clear the shaft now rests gently up against it. Good thing i only play in the notches and washes. Rocks would have made a mess. Guess its time to call Jess. |
Member # 76572
If all 3 of the joints in the front shaft are new then the Cv is probably binding up due to the angle from the new lift or you left something loose when you installed it.
I have seen the bolts back out where it attaches to the T-case and make one hell of a racket. or it's hitting something
The Bandit Last edited by crackwheeling; 01-09-2007 at 09:52 PM. |
