rear axle spring perch width: K5 v. K30 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-20-2007, 04:41 PM   #1 (permalink)
Member # 17896
I can't go measure my K5's rear spring perch width, since it's snowed in, but what, if any, is the difference between the K30 and the K5 perches??? 14 bolt is still in the garage so if I need to move the perches I'd rather do it now.
Thanks ladies.
tacoma73 is offline   Reply With Quote Quick reply to this message
Old 01-20-2007, 04:50 PM   #2 (permalink)
Big One's Avatar
Member # 48525
They're both 42", just went and measured them.
[FONT=Lucida Sans Unicode]If Big is good, Bigger is better![/FONT]
'83 Toyota Pickup (It's not exactly stock)
'91 Dodge W250 CTD 5-Speed
Big One is offline   Reply With Quote Quick reply to this message
Old 01-20-2007, 05:03 PM   #3 (permalink)
Member # 48607
Should be a dirrect bolt in with the only change needing to be the u-joint at the d-shaft. They make a conversion joint i dont have a number but being in Utah, you have a six states distributor there and they have all the spicer part numbers.
5trucks is offline   Reply With Quote Quick reply to this message
Old 01-21-2007, 03:43 AM   #4 (permalink)
Member # 4140
If both are '73 - '87 vintage, the Blazer will have a considerably wider spring spacing than the K30.
Tim
There is no accounting for taste
1936, 1937, 1943, 1950, 1952, 1954, 1955, 1997, 1998, 2002, [B][COLOR="Red"]2008[/COLOR][/B].
Black Dog is offline   Reply With Quote Quick reply to this message
Old 01-21-2007, 09:57 AM   #5 (permalink)
Member # 74869
k30's had a 40 1/2" center to center, along with 1st gen blazers, but 73-87 were 42" on the 1/2 and 3/4 tons
'72 k5 6" lift 35's d44+12bolt w/4.56 and detroits sm465/np205
Blazed_bowtie is offline   Reply With Quote Quick reply to this message
Old 01-21-2007, 10:06 AM   #6 (permalink)
Member # 17896
damn, forgot to put the years again:
Blazer is an 89, axle is 85-86ish? out of a CUCV. Guess I'd better break out the shovel and the snowpants LOL
Thanks guys!
Old 01-21-2007, 06:40 PM   #7 (permalink)
Member # 25964
I have an '85 K30 14FF - so would that be 40.5" center to center - correct?
What is the center to center on a 1989 1/2ton Burb? - if you happen to know that would be appreciated. The Burb is buried in the snow also until spring (and 30 miles away from my house).
I'm just ordered these spring perches:
http://www.ruffstuffspecialties.com/...ring-p-63.html
lebowski is offline   Reply With Quote Quick reply to this message
Old 01-21-2007, 06:52 PM   #8 (permalink)
Member # 4243
Agreed.
~2" difference, and the shocks are inboard vs. outboard.
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
