chev dual alernators - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2007, 08:38 PM   #1 (permalink)
Member # 85561
i have a 93 s15 jimmy 4.3,and i would like to add dual alternators to power extra lights ,winch ect. how would i go about wireing the second alt in to my existing electrical system.thanks
diesel dale is offline   Reply With Quote
Old 01-23-2007, 08:52 PM   #2 (permalink)
79chevy39.5's's Avatar
Member # 67935
i would just run the power wire to the bat.....kinda ghetto but easy
79chevy39.5's is offline   Reply With Quote
Old 01-23-2007, 10:48 PM   #3 (permalink)
reddman's Avatar
Member # 39492
Cut the brown wire going to your current alternator, use a good connector and reconnect it with 2 leads coming out the end, and take the new lead to the input on the new alternator. There is likely a power distribution block on your firewall, in not route the power wire to the battery. If you ditch the AC the bracket is nearly perfect for a second alt.
click the link in my sig for pics of my dual alt setup.
reddman is offline   Reply With Quote
Old 01-24-2007, 06:55 AM   #4 (permalink)
Member # 85561
my ac doesent work anyways so that braket would work fine,thanks for the help
Old 01-24-2007, 03:19 PM   #5 (permalink)
Member # 80184
Saw the way you used the ac bracket for a dual alternator, I did the same but I kept the ac in for onboard air, and since the smog pump was already gone I used that area for the second alternator, one of the bolt holes that held the smog pump in worked well and all I had to do was weld in a pair of aluminum tabs for the other end of the alternator... I'll post a picture of it as soon as I can get one... so you are running the alternators in parrallel but one of them gets really hot? Is there another way to run them and avoid early failure due to the over heating??
Forced_Overtime is offline   Reply With Quote
