Chevy Bellhousing question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-26-2007, 01:23 PM   #1 (permalink)
Member # 44136
Ok, here is my situation. I have a 72 blazer with a TH350/205. I am switching that over to a 465/205. I am also changing to a hydraulic stlye clutch using a kit from novak to mount the slave cylinder. I have everything (more or less) that I need to do this except the bellhousing.
I need an aluminum bellhousing due to how the slave clyinder mounts on the bottom two holes of the bellhousing. It also needs to house an 11" clutch.
Are there any experts on part numbers here? I know that part #3899621 will work, however, it is a highperformance unit that came behind corvettes and stuff, so is therefore big bucks. Some of the other part numbers that will work with my slave clyinder are:
3840383
3788421
3858403
462606
460486
6263756
15998496
My question to the experts is will any of these clear the 11" clutch? I tried Novak, but they didn't know if these would clear the 11"clutch.
Snowbird13 is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 04:42 PM   #2 (permalink)
Member # 49697
Send a message via AIM to PrerunnerRob Send a message via Yahoo to PrerunnerRob
Hydraulic clutch bellhousing
Just FYI, if you havent bought the Novak kit yet, you can get a 1 ton gm truck bellhousing for the sm465 with a hydraulic slave cylinder mounting boss cast in, and use the gm master cylinder. As far as using other bellhousings, just make sure they clear that huge bearing used on the sm465.
PrerunnerRob is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 06:40 PM   #3 (permalink)
Member # 52164
Novak Just get the clutch retrofit kit and go with it. I went from auto to stick and built my own kit using the novac pic's. It works, and I am running the 11".
badk5 is offline   Reply With Quote Quick reply to this message
Old 01-27-2007, 05:31 AM   #4 (permalink)
Member # 343
I agree on the high performance one NOT working.....well, not without opening up the hole. If it was from vettes, camaros, chevelles etc...it housed a "car" Muncie (M20, M21 and the great M22 "Rockcrusher") and not the larger bearing "hole" in the bell for the SM465.
cj8scrambld is offline   Reply With Quote Quick reply to this message
Old 01-27-2007, 11:36 AM   #5 (permalink)
Member # 4243
73-84 aluminum truck bellhousing. There is only one type (knocks on wood ) It has the 5.125" center hole, and a ball-stud on the side. You will probably trip over several at the PYP.
And why run a puny 11" clutch when it will take a 12"?
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 01-27-2007, 11:43 AM   #6 (permalink)
Super Steve's Avatar
Member # 83996
Send a message via AIM to Super Steve
a bellhousing from a comarro, chevelle ect has a 30 degree offset too. i bought a bellhousing not noticing and am very mad.
and hydraulic clutches started in 1985 till present in all stick trucks 85'-present
83 k30 on 42s with a stroked big block, ongoing body off for over a year... still not done
Super Steve is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 07:44 PM   #7 (permalink)
Member # 52164
My bad ...am runnig 12" set up, with hydro.
