14 bolt ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2007, 08:46 PM   #1 (permalink)
Member # 37916
14 bolt ?
I need some info about 14 bolt axles. I am running a 14 bolt out of a cucv under my Toyota truck and I have a dually dana 60 up front. I am also running H1's so the dually front works great but the problem is I am at about 77" wide in the front and 67" in the rear. I had thought about running 3" spacers but that still leaves me 2" short on both sides. I thought I read somewhere that a dually 14 bolt was 72" wide and the hubs are interchangable with the single wheel 14 bolts. If this is true I could swap them out and run 2" spacers and the widths would be about the same. I dont want to swap out the entire axle because I have already welded up the new spring perches.
I guess my question is what parts are interchangable between a single wheel and dually wheel 14 bolt?
Thanks for the help
krawlinyota is offline   Reply With Quote
Old 02-01-2007, 09:07 PM   #2 (permalink)
coolmudrunner's Avatar
Member # 55685
Send a message via MSN to coolmudrunner
Did you check the Bible??
14 Bolt Bible
Run what you brung, hope you brought enough.
[SIZE="5"][URL="http://www.pirate4x4.com/forum/showthread.php?t=437646"]4-Linked my fullsize[/URL][/SIZE]
coolmudrunner is offline   Reply With Quote
Old 02-01-2007, 09:38 PM   #3 (permalink)
Member # 4243
DRW hubs make the track narrower.
SRW hubs make the track wider.
The closest match is to get 72" wide DRW 14bolt (92+) or a Dana 70HD (73-91) and swap on the SRW hubs.
90-93 CTD jalopies
u2slow is offline   Reply With Quote
