| View Poll Results: Should I build a 383 or a 406 sbc | |||
| 383 |
10 | 28.57% |
| 406 |
25 | 71.43% |
| Voters: 35. You may not vote on this poll | |||
Member # 86618
383 or 406 sbc
i want to build a new motor for my 1984 Blazer i can't make up my mind if i want to do a 383 or a 406, i have to keep all the smogstuff on it so the cam and carb will be mild. What do you think?
Everyday Wheeler
Member # 83086
Is $500 the going rate in Cali? If so ouch! Here in Tx I wouldn't give more than $150 for a 400 block and usually pay less. Imho go with 406 you can't beat cubic inches, but a 383 is usually easier to build. A 350 block is easier to find and the 383 crank kit is not to bad pricewise.
Will
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
Member # 52752
without a doubt go 406. goto the bookstore and find a book called building big inch chevy small blocks. In the back they build a very mild 406 with vortec heads and it gets in 500s for tq and the 400 for hp. They show dyno sheets.
micky and 500 bucks for a 400 block? that has to hurt, I can get them from my machine shop for 250 and they have been checked. |
Member # 67299
a 383 is no easy to build than a 400, i runa 383 witha truck avenger carb and it kicks ass, i push 460 ft lbs and 450 hp, why are you keeping all the smog equiptment?? oh i see cali. anyways you can find some nice stoker packages for a 350 which will give you some good power
#12 (permalink) |
skullfuckery
Member # 29016
383, any 350 block
still is a 400 crank any head without moding it stronger cylinders 406, any head can be used BUT you have to drill steam holes in them!!!! not as common block will over heat like a m/f if not cooled excesively.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#13 (permalink) |
Member # 29622
BS. it wont over heat anymore than any motor that has an insufficient cooling system. they have a bad rap for overheating because of morons not drilling steam holes in the heads and such. |
#16 (permalink) |
Beer crawler
Member # 39901
400 block, 350 stroke crank
. Use long rods and let it bark. Builds more power and torque with the longer rods than the 350 block and 400 crank. Last's longer with less side loading of the pistions.
my 90 project Save a tree, eat a beaver. There are two keys to life, leverage and lubrication. Sometimes you need both. Because there is no 2nd chances on Pirate! |
#18 (permalink) |
Member # 23843
The 383s i have built never made the power a comparable 406 did!!!!I am in the process of building a 406 with 6.0 rods right now for a street rod project!!!!I cant wait!!!!Go big!!!!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!! Last edited by Rock Ape; 02-26-2007 at 02:58 PM. |
#19 (permalink) |
Member # 343
I would go 400 long rod as well. As far as making more power, it does/can but I think it is marginal. Long rod motors are less sensitive to detonation as it offers a longer dwell time.....again as with the long vs. short rods there are other factors that play into that. I like the 400 because of it's significantly larger bore, it can make any head flow better due to unshrouding the valves by the nature of the larger bore. I would think 350/400 built comparably, the 400 would offer more downward push on the piston (comp ratio being equal) due to the larger surface area. Go 406, you won't be dissapointed.
#20 (permalink) |
skullfuckery
Member # 29016
377's are a race high rpm motor for dirt track type stuff, where the rpms stay high and dont need to low end grunt much. still a good combo but the 383/406 will out pull it any day from the line.
#21 (permalink) |
skullfuckery
Member # 29016
they are between the cylinders at the narowwest point top and bottom.
#22 (permalink) |
Member # 34987
Uh, not to hijack. I am in the process of building a 406, and when the block was prepped, the steamholes were plugged. Will I have a heat problem?
1 TON SAS'ed C1500 ECSB on 37s |
#23 (permalink) | |
Member # 29622
any competent machine shop can drill the holes for you. from AFR's website: 400 BLOCKS: Steam holes are recommended for all 400 block applications (GM blocks only). Use a 400 Gasket as a template and drill the three holes, nearest the spark plug side of the head, straight down. The other three which are very near the head bolt holes should be drilled at a 30° angle away from the bolt hole. The center hole will intersect water about 1" down and the two outboard holes to a depth of 2 1/4". Use 1/8 drill. |
#24 (permalink) | |
skullfuckery
Member # 29016
350 and small sbc use a seperate tube to make each cylider wall, the 400 all of the cylinders are connected together "siamiesed"
