14 Bolt HELP!!!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-21-2002, 03:15 PM   #1 (permalink)
Member # 8271
14 Bolt HELP!!!!!
OK WHAT THE FAWK DO I HAVE TO DO TO GET THIS FREAKIN CARRIERE OUT? PLEASE HELP!!! The ring gear is hitting the housing for the bearing that supports the very end of the pinioin.....
TJ Valis <> 85 Jeep CJ-7 In Pieces
[url=http://www.tntoffroad.com]TNT Offroad[/url]
TNTOFFROAD85CJ is offline   Reply With Quote
Old 05-21-2002, 03:33 PM   #2 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I had the same problem. You have to loosen the side gear shims. (The things with the holes in them.) They are threaded. Try to only loosen one side if you plan on returning to the same backlash.
J. J.
patooyee is offline   Reply With Quote
Old 05-21-2002, 06:55 PM   #3 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
bearing adjusters.
You probably want to mark them and count the turns.
I think you have to screw them both all the way out to remove teh carrier, don't you?
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote
Old 05-21-2002, 09:06 PM   #4 (permalink)
Member # 5472
Originally posted by reddwarf
bearing adjusters.
Thats what I did. Mark the top center, unscrew counting turns as you go then you just lift the carrier out. Really simple process.
Did you ever notice: When you put the 2 words "The" and "IRS" together it spells "Theirs?"
spoolnaround is offline   Reply With Quote
Old 05-22-2002, 02:50 AM   #5 (permalink)
Member # 8271
Thanks guys It came right out..feel kinda dumb now after prying on the thing all afternoon
