Pre 88 Chevys' Running 44"s - Post Up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2007, 11:28 AM   #1 (permalink)
Member # 48424
I've gone through all of the "Important : Show a picture of your chevy" photos, and still have not been able to make my decision. If you have a pre 88 chevy and are running 44"s (Super swampers preferably) please post up some pics.
All I really need to know is the amount of lift (body, suspension etc) and some pics.
I can't decide if I want to run 44"s with 8" of lift or 10". I will probably go with 10" simply because I am going to swap a classic body onto the frame eventually and I don't want to hack it to pieces. However, the stance is very very important to me so I need some photos.
Thanks guys.
I Love Grits is offline   Reply With Quote
Old 04-07-2007, 11:49 AM   #2 (permalink)
American's Avatar
Member # 12257
Send a message via AIM to American
I think you should run 6" I did.
And I didn't even have to cut that much... it' just a firewall.
EB Truggy on 39.5's - FOR SALE $6,000 obo
TopOffroaders buggy by CBfabwerks: in the works
5.3, th400, np205, hp60, 10.5", 18" CO's, 43's, H1's
American is offline   Reply With Quote
Old 04-07-2007, 03:35 PM   #3 (permalink)
Member # 85663
RE:pre 88 chevy's running 44"s
hey dude,my dad told me he had 11 inches of lift and he was running 44"s on his truck.most chevy's ive seen running 44"s usually have 12" superlift springs and sometimes a 3" body lift.If you run 44"s with only a 12" lift,you will probably have to cut the fenders.the 3" body lift will eliminate this.this is all second hand info,so im not guarenteeing its right.
x1984dodgetruck is offline   Reply With Quote
Old 04-07-2007, 04:27 PM   #4 (permalink)
American's Avatar
Member # 12257
Well take it from someone who actually has run a 12" superlift (myself), and a 3" body lift, and don't do it.
Run as little as possible.
Old 04-07-2007, 04:33 PM   #5 (permalink)
snick's Avatar
Member # 72123
Not the best pic but.....
6" springs 3" body lift.
[url]www.consaforanch.com[/url]
VHR #471 VTR #343
snick is offline   Reply With Quote
Old 04-07-2007, 05:28 PM   #6 (permalink)
reddman's Avatar
Member # 39492
reddman is offline   Reply With Quote
Old 04-07-2007, 05:30 PM   #7 (permalink)
1980Jimmy's Avatar
Member # 43687
STOP YOUR BITCHIN!
1980Jimmy is offline   Reply With Quote
Old 04-07-2007, 05:45 PM   #8 (permalink)
Member # 53382
Send a message via AIM to SouthernK5
im too much of sissy for 44's, so the k30's 39.5's will have to do for now. 6" susp and 3" body
my k5 has 9" susp and 42's in this pic
'85 k30 with crawl ratio of 140:1
'88 k5 on 39.5 iroks
muddybuddy on ck5
SouthernK5 is offline   Reply With Quote
Old 04-08-2007, 10:17 PM   #9 (permalink)
Member # 73413
trust me on this one, even with a 12" kit and a 3" body lift, you will hit the fenders under hard use. I even managed to smash in the firewall a little.
Bansheestu is offline   Reply With Quote
Old 04-08-2007, 10:21 PM   #10 (permalink)
Member # 48424
Did you have to cut/rotate the knuckles on that K5 ? What brand did you go with, how did you get the lift (shackles /springs/blocks etc) and how is the ride? Any reccomendations?
Old 04-09-2007, 06:50 AM   #11 (permalink)
44boggers's Avatar
Member # 67299
i have an 86 chevy with 44's
3inch body
8 inch suspension but with shackle flip and longer shackles i makes around 12 inchs of lift i still had to cut the fenders some to , for some reaosn i cant find the attachment button to post a pic.
44boggers is offline   Reply With Quote
Old 04-09-2007, 08:08 PM   #12 (permalink)
panty dropper's Avatar
Member # 23462
Send a message via MSN to panty dropper
I have 12 inch superlift springs front with 1 inch of shackle and maybe 1/2 inch from the dana 60 (the tubes are bigger around than the old 44) and the rears are 8 inch superlifts, 4 inch shackle flip, 2 inch angle lift blocks along with a 3 inch body lift and bushwacker cut out flares take about 2 inches front and rear of each fender well and the 44 inch swampers still hit the fenders when I stuff the nose into a rut or ditch. I am going to move the front axle forward a little before the 49's go on. And save some time, get hydro crossover steering the first time. And if you are going to run superlifts, get dual shocks. Rear driveline angle is fine, front is fucked. I didnt turn the knuckles or anything on the 60, The angle of the d-line is bad at the transfer case end, front axle is running stock caster. I am going to lower the engine and tranny a few inches when the 455 goes in, along with a nw adapters doubler kit which will rotate the transfer case 4 inches down so I can actually wheel it without the horrible noises from the front driveline.
89 yota/3.4 swap/auto/33 stt's
87 runner/3.4 swap/33 toyos
78 chev k30/400/th400/44 swampers
77 chev k20/400/th350/36's, no lift, lincoln locked front and rear
79 blazer-getting piratized as we speak
84 runner/9 inches taller,3.4/auto/crawler etc soon
[url]http://www.myspace.com/slater442w30[/url]
panty dropper is offline   Reply With Quote
Old 04-10-2007, 03:05 PM   #13 (permalink)
Member # 53382
the front is 8" BDS springs, with a 1" zero-rate offset 1.5" for more driveshaft length to help the angle. the front axle just has 5* shims on it. i was running the stock driveshaft with a 1350 conversion u-joint. i was eventually going to run a custom shaft to help the angle, but the 1" offset zero-rate really helped. the rear was 4" home made shackle flip and 5" lifted 64" springs from a newer 1500. the truck ran down the road perfect up to 70mph and made several long (250miles each way) road trips w/o any problems as well as tore up trails with ease. if you want to run 44's definitely move the front axle as far forward as possible, to both help prevent hitting the firewall when flexing and give the driveshaft more length to help the angles. anything else let me know
muddybuddy on ck5
Old 04-10-2007, 06:15 PM   #14 (permalink)
Member # 43029
This is my 86 burb
Before I went rocks i had superlift 12'' front springs Superlift 8'' rears and offroaddesign.com shackle flip hangers heavy duty shackles front and rear. I had to cut the back of the front fenders out and ran 16.5x10 wheels with 4'' backspacing i think. I could turn lock to lock without hitting and i could stuff them pretty good before rubbing. I did have a nasty hole i hit and the rear tire slammed the passenger rear fender. Oh well. It rode very well where i could eat a burger and steer with my knee. BUT i also had crossover high steer and pretty true tires.
suburban N progress is offline   Reply With Quote
Old 04-10-2007, 06:16 PM   #15 (permalink)
Member # 43029
Here is a before pic :foff:
here is with rocks
Old 04-10-2007, 07:55 PM   #16 (permalink)
Member # 49663
Send a message via AIM to 87GMCsierra
that burb is clean.
87 GMC 350tbi 465/twin sticked 205 H.A.D. front shaft one tons locked stock 52's and 56's 39.5 tsls
87GMCsierra is offline   Reply With Quote
Old 04-10-2007, 08:00 PM   #17 (permalink)
Member # 43029
thanks!! Just wait..getting more done to it..will post a build on it soon.
Old 04-11-2007, 06:25 AM   #18 (permalink)
Member # 44659
My 88 K5 has a shackle flip, 52's up front, a 1 inch ORD body lift and I run 44's. I would run it this low all the time. A little trimming of the fenders and I was good to go.
Here is the link to the video of it.
http://idahostate4x4association.com/video/lumpdog.wmv
88K5 14b/d60 Self destruct mode switched to on! 97 Xcab Dodge crawler in the works. 77fj40/94fzj80
lumpdog is offline   Reply With Quote
Old 04-11-2007, 09:23 AM   #19 (permalink)
Member # 44659
Found one pic
Old 04-11-2007, 02:19 PM   #20 (permalink)
Shadowfox's Avatar
Member # 79169
Send a message via AIM to Shadowfox Send a message via Yahoo to Shadowfox
nice blaze
[COLOR="Red"]"If it won't fit force it! - If it breaks it was no good anyways"
[/COLOR]
Shadowfox is offline   Reply With Quote
Old 04-12-2007, 05:58 AM   #21 (permalink)
Member # 43563
22" of Lift and I still hit my fenders "bet I hear s.h.i.t from this on pirate"
1978 Chevy Pickup 454cid 46" turf & fields Showtruck
2003 GMC crewcab Pickup Banks 6 Gun 6" lift 35" Tires
1984 Blazer cut up and welded back together..he..he
[URL="http://www.myspace.com/biorick"][COLOR="Blue"]http://www.myspace.com/biorick[/COLOR][/URL]
Biorick78 is offline   Reply With Quote
