Vortec 5.3 vs 4.8 identification - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2007, 02:17 PM   #1 (permalink)
Member # 36444
Is there any way to ID the engine size from outside, there is a Gen III engine at the junkyard that is really cheap, $300 with no accesories but the guy form the junkyard doesn´t know what engine size is, I already have the casting number 12577396, but it is the same number for both block sizes.
It also has a sticker on the outside that says FJB in big bold letters.
I know that you can tell by opening the oil pan and look for the casting numbers on the crank, is there any other way? thanks in advance.
kihm is offline   Reply With Quote
Old 04-07-2007, 02:33 PM   #2 (permalink)
Member # 42472
Send a message via AIM to WhatsStuckK5
Not too many other ways. the only way i knew mine was a 5.3 is the fact that it has the flex fuel injectors, which are were only on 5.3s in 02. the pistions and crank are seriously the only things that are typically different. sometimes the small stuff, like i said injectors, may be different, but unless its flex fuel, theres not much other way to tell...
WhatsStuckK5 is offline   Reply With Quote
Old 04-07-2007, 06:50 PM   #3 (permalink)
Member # 88445
The blocks are interchangable The only differences are internal. For $300, it is a good deal eather way.
88smurfj is offline   Reply With Quote
Old 04-07-2007, 07:29 PM   #4 (permalink)
Banned
Member # 87243
you might try to shine a light in the spark plug hole to see if the pistons are dished or flattops. dished-5.3, flats-4.8.
1969x11 is offline   Reply With Quote
Old 04-07-2007, 10:47 PM   #5 (permalink)
Member # 36444
Thanks, I'll try that...
