Broken Steering arm studs on Dana 60? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2007, 03:17 PM   #1 (permalink)
Member # 47359
In september I swapped in a dana 60 into my truck and put in a superlift steering block since the truck has a 4" lift. About a month ago i noticed the steering seemed sloppier than normal so i checked out all the steering components and found that two of the 4 studs holding the block and steering arm had sheared off at the knuckle! I've tried extracting the broken studs but so far I haven't had any luck at that. Even if i get them out and replace them, I'm afraid that they'll just break again. I've also thought about boring the stud and knuckle out and using larger studs.
Has anyone else had their d60 steering arm studs break? Any helpful advice on what to do next would be greatly appreciated.
chevboy171 is offline   Reply With Quote Quick reply to this message
Old 05-09-2007, 03:56 PM   #2 (permalink)
Member # 88208
crossover steering
so pirate
tomshouse516 is offline   Reply With Quote Quick reply to this message
Old 05-09-2007, 04:06 PM   #3 (permalink)
Member # 25964
I have the same setup - no problem with the longer studs for 17yrs now. I want to get new studs when I do the next teardown though. If you find a source for the longer studs please post.
lebowski is offline   Reply With Quote Quick reply to this message
Old 05-09-2007, 05:15 PM   #4 (permalink)
abig84's Avatar
Member # 88383
last resort you can always drill and use a easy out or reverse drill bits if they make them that big. or if you really have to drill the intire thing out and retap it.
abig84 is offline   Reply With Quote Quick reply to this message
Old 05-09-2007, 05:45 PM   #5 (permalink)
tlspeed1's Avatar
Member # 38739
This on the cheap and works well. In order to get longer and bigger bolts, we have used leaf spring centering bolts for heavy truck leaf springs. Bascially it is fine threaded, fully threaded rod thats grade 8 rating. Just cut to length and clean the cuts up and ready roll. I know of 2 rigs running them, one using the stock size, 9/16, and the other running 5/8 no problems in over 2 years now.
Any heavy truck parts place should have them, and some auto pars store might be able to get them to.
tlspeed1 is offline   Reply With Quote Quick reply to this message
Old 05-14-2007, 10:25 PM   #6 (permalink)
Member # 47359
Thanks everyone for your help
I've found 9/16" (the original studs were 1/2") 18 thread rod for a reasonable price and i'm going to drill and retap the knuckle. The rod is the same rated strength as the studs were (b7 alloy i think). The only foreseeable problem now is finding tapered nuts to fit on the new rods, i'm hoping the local tire shop can help me find some matching lug nuts.
Old 05-14-2007, 10:41 PM   #7 (permalink)
trkklr77's Avatar
Member # 29016
use the d44/10b cone nuts they are 9/16, but much wider so???
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 05-15-2007, 01:03 AM   #8 (permalink)
Member # 41764
Were all sides bare metal and torqued to spec? Somehow I doubt it.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 05-15-2007, 09:57 PM   #9 (permalink)
Member # 47359
I had a reputable alignment shop that i've had good experience with in the past install the block when i was having other work done. I would hope that he torqued it correctly, but if it was installed correctly, then i don't know why it would have broke.
Old 05-17-2007, 03:05 PM   #10 (permalink)
Member # 76815
I had the studs break on my truck, I was backing into the driveway when they snapped. I have since gone to crossover steering and have no issues. Had I known that crossover was this much of an improvement, I would have done it when the lift was put on.
1985 M1008
(k30 for you civilian minded people)
6.2L Diesel w/ Banks Turbo
Rear Disc Brakes
6" lift springs (Superlift)
DIY4X Shackle Flip
38.5" ground Hawgs on Humvee rims (not Re-centered)
just completed crossover steering
ITS MY DAILY DRIVER :D
ccatlett1984 is offline   Reply With Quote Quick reply to this message
Old 05-24-2007, 01:34 AM   #11 (permalink)
Member # 47359
So one of the two studs decided it didn't want to get drilled out in a straight line. I'm gonna pull the knuckle off and will probably end up having to get a new knuckle. I plan on getting crossover eventually, but either way, i still need to get the drivers side figured out as it holds the knuckle/kingpin together. If i can't find a stock knuckle (i think they're discontinued), i'll prolly get a dedenbear. Anyone have any recommendations?
Old 05-24-2007, 09:54 AM   #12 (permalink)
Member # 88150
i have new stock knuckles in stock,let me know
randysoffroad is offline   Reply With Quote Quick reply to this message
Old 05-30-2007, 02:36 PM   #13 (permalink)
Member # 47359
Dedenbear says their knuckles are for offroad use only. I found a new stock knuckle and just ordered it...this little problem has turned into a big pain in my @$$ and a bigger hit to my wallet than i expected, i guess thats how most projects nad problems end up though.
