Member # 90142
2 transfer cases on the same truck?
ok, ive been seeing a couple of guys running trucks with a 4speed with a 205 bolted up and then ran a divorce transfer case in the back, anyone else seen this set up? Im wondering what the Plus is of running this set up?? any info.
#2 (permalink) | |
Addicted to Gear Oil
Member # 56050
Gives you another low range. Search for transfercase doubler.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
OCX Off Road Audio
Member # 72810
I'm running a SYEed 241 to a divorced 205. The benefits are 2 low ranges to choose from, or a double low. Also, with a longer wheelbase you can have a longer front shaft for better u-joint angles. With a divorced doubler you can even position the case so both shafts are the same length so you can carry just one spare.
Custom Speaker Cans for Your Buggy, Side by Side, or Boat LIKE US Use PBB15 for $15 OFF Order of $130+ |
