Chevy IFS exploded drawing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2007, 12:12 PM   #1 (permalink)
houckxlr8's Avatar
Member # 91330
Can anyone tell me where to find an exploded view drawing of my front diff on a '94 Chevy K1500.
houckxlr8 is offline   Reply With Quote
Old 05-14-2007, 03:24 PM   #2 (permalink)
Member # 54978
Send a message via AIM to Mud Slayer 2.0
Go wheel it and it'll explode sooner or later. then Ta Da !
Honestly all in all ive looked all over the net for exploded drawlings of stuff and only luck ive had were with paper manuals or online manuals u pay for.
Mud Slayer 2.0 is offline   Reply With Quote
Old 05-14-2007, 03:42 PM   #3 (permalink)
houckxlr8's Avatar
Member # 91330
The driver side of my diff wiggles and I just need to know if there is a replacable bearing in there and how hard it is to replace. An exploded "PICTURE" would be all the reference I would need. If there are only manuals could you refer me to them?
P.S. Michigan kicks A$$. I am in the military in South Carolina now, but I'm a born and bred Yooper!!!!!
Old 05-15-2007, 06:51 PM   #4 (permalink)
Member # 38771
The best I could find is a 2000 but I think it should be relatively close since they're both GMT800 trucks. Sorry for the choppy res, that's the best I could get off the system. Here ya go...
(1) Front Drive Axle Inner Shaft
(2) Front Drive Axle Inner Shaft Seal
(3) Front Drive Axle Inner Axle Shaft Bearing
(4) Front Drive Axle Inner Shaft Housing
(5) Front Drive Axle Clutch Gear Thrust Washer
(6) Front Drive Axle Clutch Gear
(7) Front Drive Axle Inner Shaft Retaining Ring
(8) Front Drive Axle Clutch Sleeve
(9) Front Drive Axle Clutch Shim
(10) Front Drive Axle Actuator
(11) Front Drive Axle Inner Shaft Housing Bolt
(12) Front Drive Axle Clutch Fork Shaft
(13) Front Drive Axle Clutch Fork Outer Spring
(14) Front Drive Axle Clutch Fork
(15) Front Drive Axle Clutch Shaft Retaining Ring
(16) Front Drive Axle Clutch Fork Inner Spring
(17) Front Drive Axle Clutch Shaft Bearing
(18) Front Drive Axle Clutch Shaft
(19) Front Differential Carrier Bolt
(20) Front Differential Carrier
(21) Front Differential Carrier Half Location Pin
(22) Front Differential Case Bearing
(23) Front Differential Bearing Adjuster Nut
(24) Front Differential Bearing Adjuster Nut Sleeve
(25) Front Differential Side Bearing Cup
(26) Differential Ring Gear Bolt
(27) Front Differential Side Bearing
(28) Front Differential Pinion Gear Shaft
(29) Front Differential Case
(30) Differential Pinion Gear Shaft Lock Bolt
(31) Differential Side Bearing
(32) Differential Side Bearing Cup
(33) Front Differential Ring Gear
(34) Front Differential Half Carrier Location Pin
(35) Front Differential Bearing Adjuster Nut Lock
(36) Differential Pinion Gear
(37) Differential Pinion Gear Thrust Washer
(38) Differential Side Gear Thrust Washer
(39) Differential Side Gear
(40) Differential Pinion Gear
(41) Differential Pinion Gear Thrust Washer
(42) Front Differential Side Gear Spacer
(43) Front Differential Side Gear
(44) Front Differential Side Gear Thrust Washer
(45) Front Differential Drive Pinion Gear
(46) Differential Drive Pinion Gear Bearing Shim
(47) Front Differential Drive Pinion Gear Inner Bearing
(48) Front Differential Drive Pinion Gear Inner Bearing Cup
(49) Front Differential Drive Pinion Gear Bearing Spacer
(50) Front Differential Carrier Bushing
(51) Front Differential Carrier
(52) Front Differential Bearing Adjuster Nut Lock
(53) Bolt
(54) Front Differential Drive Pinion Gear Yoke Nut
(55) Front Differential Drive Pinion Gear Thrust Washer
(56) Front Differential Drive Pinion Gear Yoke
(57) Front Differential Drive Pinion Gear Bearing Dirt Deflector
(58) Front Differential Drive Pinion Gear Seal
(59) Front Differential Drive Pinion Gear Outer Bearing Cup
(60) Front Differential Drive Pinion Gear Outer Bearing
(61) Front Differential Carrier Bushing
(62) Differential Bearing
(63) Front Differential Bearing Adjuster O-Ring Seal
(64) Front Differential Bearing Adjuster
(65) Front Drive Axle Inner Shaft Seal
(66) Front Drive Axle Inner Shaft Retaining Ring
(67) Front Drive Axle Inner Shaft
(68) Front Differential Carrier Vent
(69) Fuel and Oil Resistant Hose
(70) Clamp
(71) Front Differential Carrier Vent Hose Connector
(72) Front Differential Carrier Oil Drain Plug
(73) Front Differential Carrier Oil Drain Plug Washer
(74) Front Differential Carrier Oil Fill Plug
(75) Front Differential Carrier Oil Fill Plug Washer
Joe
'88 GMC K5, lots of dents
'01 Chevy 2500HD D/A
"It's only sheetmetal!"
Joe_88k5 is offline   Reply With Quote
