Member # 65290
Truggy Build.
Hello,
I know I am new here however I have been waching pirate for a long time. This is the build I have had a friend working on for a while. Im getting down to the final stages and thought you guys might want to take a look. Also would you guys know a good starting pressure and oil level for the 18" SAW air shocks? Here are some pics http://picasaweb.google.com/Blackcj5/K1500MIRANDA Here are the specs 85 k1500, 10.25 sterling rear (welding), Dana 60 front , 350 small block, new th350, np203, buggied behind cab with 4link rear, 18" SAW air shocks, rear leaves on front, rock sliders, beer keg fuel cell, 36" TSL SX's on H1 12 bolt wheels, and cutout fenders on the front. Last edited by kyCJ5guy; 05-15-2007 at 08:31 PM. |
Member # 88364
get some better front shackles. it looks like the stock ones you are using have the spring end resting on the frame. ORD sells a kit that comes with greasable bushings, thicker bolts and longer thicker shackles. At the very least make one that are twice as thick as stock and longer.
Member # 32786
You might want to do something about your battery hold down as well.
79' K10 350 F.I./ TH350/ NP203/NP205/D60/14FF & 42's 02' GMC crew cab D-Max 79chevyk10 everywhere else. Save The Hammers Rally Post #314 Tellico Rally Post #20 |
Nice fab work, but you should think about making some square drive lines.they are stronger and look better. but over all.... stronger.
And going off the other guy, work on the shackles. From the looks of things, your guy knows how to fab(so-so),, have him fab you up some shackles. see ya on the trails... |
#6 (permalink) | ||
I was just going to ask why the hell there was a sterling in there. Get a real axle this is a chevy not a ford.
~Philip Midwestern 4x4 Parts Quote:
89 S10 Truggy |
#8 (permalink) | |
EB Truggy on 39.5's - FOR SALE $5,750 obo TopOffroaders buggy by CBfabwerks: in the works 5.3, th400, np205, hp60, 10.5", 18" CO's, 43's, H1's |
Member # 65290
The sterling was free so I diddnt complain. The shackles are a known issue and will be corrected when the funds are available. The wheel base is 118 and I plan on going to 38s soon.
Question for you guys. I accidentaly ran it out of gas and now it wont start except for priming the carb. Any Ideas? |
#10 (permalink) | |
Who said I was a newbie? I am paid up , and was just curious. Around here those axle are worthless , and I was just curious why he used it . Wonder if you remember meeting me anyway's ...... I remember you that's for sure.
89 S10 Truggy |
#12 (permalink) |
Member # 47632
Checkout DIY4X.com for shackles & greasable bushing bolt kit,these are cheaper than ORD. I have used ORD shackles and just bought longer shackles from DIY4X and im very impressed with the quality of them.
#13 (permalink) | |
In all honesty, I am a self proclaimed nubcake and probably always will be. So you got me on both counts
#15 (permalink) |
Member # 5691
Fuel filter has a bunch of junk in it off the bottom of the tank maybe?
I would run the Sterling.The only problem I have heard with those is the ring gear bolts comming loose.But that can be cured easily enough
The Woohoodilly- 69 FJ55-350/465/203/205,D60/ARB,D70/Detroit w/5.86s,42"IROKs on H1s |
#16 (permalink) | |
Member # 5691
![]() I guess I need to get rid of my Dodge Dana 70.And maybe while Im at it,get rid of the Toyota body thats on my Blazer
#17 (permalink) |
Maybe we should all swap around, because I was puttin this Chevy rear axle in my Dodge... Was I breaking a rule when I had a Dodge 60 in my Chevy?
I dunno, something about the fact that it's a STERLING rear end, a DANA rear end, etc makes me not give a damn what it's out of. I want it to work, and I want it to get up the damn obstacle. Sorry for hijacking your thread, man.
#19 (permalink) | |
Member # 64748
You may be paid up but your a fucking dumb ass.
read what he wrote idiot Quote:
One of you dumbasses who were bitching is a newb....the other, yourself, is the idiot with the 10 bolts.
I caught your Jeep thing now it BURNS when I piss! |
#20 (permalink) | |
Member # 5691
![]() ![]() And since they are not in your sig along with everything else,what axles you got
The Woohoodilly- 69 FJ55-350/465/203/205,D60/ARB,D70/Detroit w/5.86s,42"IROKs on H1s Last edited by FRIZZLEFRY; 05-18-2007 at 11:31 AM. |
#21 (permalink) |
Karnage
Member # 55444
Pull the carb apart and clean it. Idle circuits are likely clogged.
As for the rest of these guys, I say build whatever the hell you want to. One question though, with how big a chevy cab is already, why make the rear cage like 6" bigger all round?
Thanks to BAILEIGH INDUSTRIAL
![]() Krush RT IFS/IRS Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color] https://www.facebook.com/KrushRacing |
#23 (permalink) |
Member # 23843
Im not bashin,but why is the cage so far away from the cab???And is there any plans for inner structure inside or outside the cab???Just curious???Im learning too and plan to build me a truggy someday.......
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!! |
#24 (permalink) | ||
89 S10 Truggy Last edited by Big91RustyBucket; 05-18-2007 at 01:34 PM. |
#25 (permalink) | |
Karnage
Member # 55444
Hahahahahahahahaha
