Factory oil cooler on TBI 350.....how to eliminate? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-01-2002, 10:40 PM   #1 (permalink)
ROKTOY's Avatar
Member # 400
I have a 1995 TBI 350 engine with factory oil cooler. Will be
using it in a light trail rig so want to eliminate the factory oil
cooler setup. It has a bolt-on aluminum housing that mates to
the block where the oil filter normally goes. The filter then screws
to this housing. I thought I could just pull the
housing and the
filter would screw to the block. No go.....must need some other
none cooler style block fitting.
Anybody know? Thanks.
Jay
ROKTOY is offline   Reply With Quote Quick reply to this message
Old 06-02-2002, 06:17 AM   #2 (permalink)
Member # 613
get an adapter off a non-oil cooler block and the bolts. It will bolt right up. Save the parts for future use might need them costly to go buy new.
odee is offline   Reply With Quote Quick reply to this message
Old 06-02-2002, 10:04 PM   #3 (permalink)
Visa Master
Mutt's Avatar
Member # 8649
Have a small line made to out and right back into the housing...
-Steve
43" Grooved SX's, H1's, Ori's, Ord Magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required...Muttlock guy
Mutt is offline   Reply With Quote Quick reply to this message
Old 06-03-2002, 08:39 AM   #4 (permalink)
Member # 4406
What odee said. I think dealer parts to do it are $20-$25.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 06-03-2002, 11:20 AM   #5 (permalink)
RootBreaker's Avatar
Member # 12010
Send a message via ICQ to RootBreaker Send a message via AIM to RootBreaker
I probably dont know what I am talking about....
but I took a oil cooler unit off of a truck before and see if you can follow this....
1. took oil filter off..
2. took aluminum adapter off
3. unscrewed threaded piece off of aluminum piece
4. screwed it straight into the block
then all was good. This worked for me but I dont know if it will for you. see if the threaded piece will unscrew from the adapter first...
hope it helped somewhat....
RootBreaker
1978 chevy 4x4
Lifted & Locked
RootBreaker is offline   Reply With Quote Quick reply to this message
Old 06-03-2002, 01:12 PM   #6 (permalink)
ROKTOY's Avatar
Member # 400
Looks like it will unscrew from the aluminum housing, but the block doesn't appear to be threaded for the fitting.
Jay
Old 06-03-2002, 04:56 PM   #7 (permalink)
Member # 12010
hmmm figures.... umm.. how about Tap dat bad boy????
that is all that they do at the manufacture???
1978 chevy 4x4
Lifted & Locked
Old 06-03-2002, 05:25 PM   #8 (permalink)
Member # 4406
IIRC there is a piece that bolts on in place of the oil filter adapter w/a factory oil cooler. Some aftermarket ones just spin on.
Pete
Old 06-04-2002, 12:20 AM   #9 (permalink)
ROKTOY's Avatar
Member # 400
Found out the dealer sells the non-cooler housing for about $20. Thanks for the info.
Anyone wanna buy a factory cooler housing along with the factory hose?
Jay
