Gov-Lock Rebuild - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-22-2007, 05:27 PM   #1 (permalink)
Member # 23027
Question Gov-Lock Rebuild
Hi, Does anyone have any information on rebuilding a gov-lock (Eaton G80 or mechanical locking differential)?
I know of their shortcomings, but I am putting one in a light passenger car and hope for better success with it than many people have with them in their trucks. First I need to tear it down and clean it before I stab it in, though.
If anyone has a factory service manual that details this and could scan the pages in I would greatly appreciate it!
Thanks, Chris
CAC91 is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 05:38 PM   #2 (permalink)
Member # 73492
GM Parts only!!
I looked at rebuilding a gov loc 5 years ago the parts were over $350.
an auburn posi is that much.
Plus you need gm service tools to get the pins out
88 Sub, 6" Lift 44F,14R Olive drab, 37" Military OZ's On Stazworks H1's
widmayer123 is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 05:46 PM   #3 (permalink)
Member # 23027
I don't doubt that for the parts to rebuild but I'm thinking I will be able to get away with a disassembly, cleaning, and reassembly. Do you have any literature about the process or pictures of the specialty tools by any chance? Thanks, Chris
Old 05-22-2007, 06:00 PM   #4 (permalink)
Big91RustyBucket's Avatar
Member # 87635
Send a message via AIM to Big91RustyBucket
I rebuilt mine. With a Lincoln Weld Pack 175HD
~Philip
Midwestern 4x4 Parts
You've inspired me to start a build thread of my own.......... all the pictures will be upside down to reflect my driving style!
89 S10 Truggy
Big91RustyBucket is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 06:20 PM   #5 (permalink)
avainaffairs's Avatar
Member # 64748
I would soak it in a pool of gasoline for a night.
Then spary the hell out of it with some break cleaner.
I caught your Jeep thing
now it BURNS when I piss!
avainaffairs is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 06:43 PM   #6 (permalink)
88K1500TEX's Avatar
Member # 29233
Id Install the gov lock into this
Seriously though I broke two spider gears on mine and the dealer wanted 300 something per gear
I ended up getting an open carrier and detroit.
I do however have a factory service manual but no scanner perhaps i could fax them to you?
88K1500TEX is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 06:53 PM   #7 (permalink)
Member # 23027
I knew I would get ridicule for this! I appreciate all the advice and warnings about this thing but like I said this is going into a 3000 pound car with 27" tall narrow tires. I am just gonna give it a shot and hope it works OK.
As for faxing the manual pages, I would love that but I have no access to a fax machine currently (unemployed). Thanks very much for the offer and I am going to try to find a fax number I can use.
Old 05-22-2007, 07:03 PM   #8 (permalink)
Member # 73492
Go to your local GM dealer and ask the parts guy
If they have ben around awhile they should have it
Doesnt mean they will let you borrow it But you may be able to see it and fab something up.
Old 05-22-2007, 07:31 PM   #9 (permalink)
Member # 23027
I've tried at a local dealership and gotten nowhere. I will try others and the same one again if there isn't someone on the board that has the info. It really all depends on who you are lucky enough to talk to. Good suggestion though.
Old 05-22-2007, 11:31 PM   #10 (permalink)
Member # 43522
Originally Posted by widmayer123 View Post
GM Parts only!!
Agreed, the cost of the parts and tools will net you a new posi.
sharpshooter is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 11:38 PM   #11 (permalink)
88K1500TEX's Avatar
Member # 29233
Well let me know if i need to get the needed pages copied and faxed m-f 9-5 i can get it done
Old 06-02-2007, 12:04 PM   #12 (permalink)
Member # 23027
Thumbs up
I finally got a fax number I can use. I will PM you with the number and if you could fax the pages I would really appreciate it. The unit I am dealing with is from an 8.5" 10 bolt from the mid 80's if you have a choice of what to look up. If not I'm sure they are all pretty similar and any info should be all I need.
Thanks a ton!
Old 06-03-2007, 05:48 PM   #13 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
The gov-bomb is not really worth rebuilding, if it's shot (or in pieces, usually) replace it with a good LSD or Locker. I've got the GM FSM for the gov-bomb. I'll scan for you.
I need to resize them, though.
guidolyons is online now   Reply With Quote Quick reply to this message
Old 06-03-2007, 05:59 PM   #14 (permalink)
guidolyons's Avatar
Member # 56050
You do need a special tool to remove the governor bushings, I made one from a C-clamp.
Old 06-03-2007, 07:04 PM   #15 (permalink)
guidolyons's Avatar
Member # 56050
Last ones:
Old 06-03-2007, 07:06 PM   #16 (permalink)
Member # 72374
I think for a daily driver CAR, the G80 is FINE. They work excellent in the snow. Plus if it's a G80 diff, you won't have to setup the diff. Just R&R. No effing around with shims or dial indicators or checking the gear pattern.
morgsie is offline   Reply With Quote Quick reply to this message
