Np208? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-19-2007, 07:36 PM   #1 (permalink)
Member # 87681
Np208?
Can you guys give me info on a NP208?
Is it chain or gear drivin?
It keeps popin out of 2H is this just detent or can there be somthing else causing it?
I just brought the truck home and don't know much about it yet.
hoss390 is offline   Reply With Quote
Old 06-19-2007, 07:41 PM   #2 (permalink)
77k5's Avatar
Member # 35786
Its chain driven and you probably need to adjust the shift linkeage
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
chrish@offroaddesign.com
offroaddesign.com
970-945-7777
77k5 is offline   Reply With Quote
Old 06-20-2007, 06:13 PM   #3 (permalink)
silveradoreb's Avatar
Member # 37431
common problem, mine does the same thing, now its always in 4 low, my fix is the 205 laying in my garage
silveradoreb is offline   Reply With Quote
Old 06-21-2007, 02:28 PM   #4 (permalink)
Member # 33838
Linkage or shift fork. Linkage is the easy one of that is it. Get under the truck and disconnect the linkage and then rotate it by hand into position and see if it still pops out of gear when you test drinve it. If it does the same thing then you have a internal problem. Drop the case and open it up.
xtrmjoe is offline   Reply With Quote
