Will H2 Wheels fit over a D60 with Warn Prem. Hubs? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-03-2007, 06:07 PM   #1 (permalink)
Member # 89305
Will H2 Wheels fit over a front Chevy D60 with internal style Warn Prem Hubs without having to grind out the center of the wheel? Also do they need to be ground to fit over a FF 14 bolt? Just need some temp wheels until my beadlocks and boggers are paid for.
Thanks
--Mike
Big1TonSub is offline   Reply With Quote
Old 07-03-2007, 06:24 PM   #2 (permalink)
Member # 35721
yes... to both they are a 1.6.5" wheel, look on pirate for some info they have a tech section on here somewhere bout what wheel work for d60's. most people either run dullie axle for the wheel or have them recentered as they are a 7" back space
73 Scout II,350tbi,700r4,twin sticked np205,4:1klune,60f,14b,4link fr/rr,coilovers fr,42"pitbulls
ih4ever is offline   Reply With Quote
Old 07-03-2007, 06:28 PM   #3 (permalink)
Member # 67237
WRONG!
your thinkin h1's, just so people dont read the wrong info, but i thought the only axle that needed the h2 rims to be machined was the dana 70.
Good enough to fuck your mother!
jeepcj75 is offline   Reply With Quote
Old 07-03-2007, 06:28 PM   #4 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
he is asking about a 17" H2 wheel, not an H1.
Damn it, u beat me to it!
'91 k3500, 454, 4speed, 42" R-1's no lift
'97 z-71, 3" BL, 38" tsl radial, 454/th400
'97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool,
34/10.50/16 ltb
Red Chevy is offline   Reply With Quote
Old 07-03-2007, 08:28 PM   #5 (permalink)
silveradoreb's Avatar
Member # 37431
I ran H2s on my 84 CUCV which has a 60/14,for a while. Fit not problem with warn standards
silveradoreb is offline   Reply With Quote
Old 07-03-2007, 10:40 PM   #6 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Send a message via AIM to svt150j49
ive heard of a problem with ford rear dana 60s and H2s, but your combo should be fine.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread:
Here
The un-named buggy - 2.3L, lotsa tube, and FJ80s.
svt150j49 is offline   Reply With Quote
Old 07-04-2007, 06:47 AM   #7 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
I think also on some dodge front axles, maybe the 94 and up unitbearing hubs. The wheel has to be clearenced a little to fit.
34/10.50/16 ltb
Old 07-04-2007, 06:53 AM   #8 (permalink)
cbbr's Avatar
Member # 34555
Thanks
--Mike
They should fit with no problem. Mine do.
Run when you can, walk if you have to, crawl if you must; never give up.
cbbr is offline   Reply With Quote
Old 07-04-2007, 08:39 AM   #9 (permalink)
Member # 67237
dudes got 700 somethin posts to
Old 07-04-2007, 11:54 AM   #10 (permalink)
Member # 88208
they deffinatly clear the chevy 60 front and im pretty sure they clear the 14bff, they do not clear ford fronts or pre-unit bearing dodge hubs.
so pirate
tomshouse516 is offline   Reply With Quote
Old 07-04-2007, 06:37 PM   #11 (permalink)
kpj
Member # 6920
I've had to grind the centers out with a dremel for a set of ford 60s and a set of GM axles (60/14 bolt). No major work, just kiss the ID of the wheel with a dremel. No biggie. So it looks like some do and some don't.
kpj is offline   Reply With Quote
Old 07-05-2007, 04:15 PM   #12 (permalink)
Valley Auto's Avatar
Member # 78079
Aww look who finally bought a star.....
Master of the wire Wheel!
Coastal Fabrication the " best damn shop in town"
Poly Performance
Pacific Fabrication
http://www.pacificfab.net/
Valley Auto is offline   Reply With Quote
