Member # 92285
Best Flexing leaf springs for my 85' K5 ????
I am looking for a leaf spring that has great flex can anyone recommend a brand ? I have been told Superlift soft ride .?.?.?.? I will be lifting the K5 a total of 6" with 36x13.5r15 iroks . I will be trimming the fenders too . I am looking to do 6" leafs in front with a 4" shackle reverse in the rear with 2" leafs but dont know what leafs to go with . thanks .
Member # 15404
52's up front and 56's in the rear with a shackle flip.
I personly like 3" wide Ford 57's in the front...they seam to last longer...
Life begins where the pavement ends! |
Wentworth Wheeler
Member # 32809
agree with the above, but if you want a spring that will just replace your current ones without much other effort, I would look into the Tuff country springs. i have the 4" HD ones and they flex pretty nicely. along with a 1" milled zero rate (to help angle) and a 1" body lift i got ~ 6" of lift. zero rate, and shackle flip in the rear.
they have a 6" spring too, but i have no personal experience with that. |
Member # 43040
52's front and 56", 57", or 63" rears are WELL worth the work. Best bang for the Buck as far as flexy leafs go.
95 S-10, one tons, 44's, 7lb pulley Last edited by Joshinator; 07-17-2007 at 04:35 PM. |
Member # 87197
Ive run 2 Tuff Country 4" HD lifts- 1 SB, one in a blazer- and have liked them fine for flex. Both rigs had standard rear shackles- one had blocks in the rear, one had Rancho(?) 4" rears springs. Depends on how much work you want to make it.
88 YJ SBC/T350/D300/4:1/D44s/35s Tellico Rally#47 - JV Rally#262 |
#10 (permalink) | |
Member # 15404
I have yet to bend one of these springs. But I bent 4 sets of 2.5" wide springs before these.....both aftermarket lift and custom ones built from 52" chevys.
Life begins where the pavement ends! Last edited by rcurrier44; 07-18-2007 at 07:43 AM. |
Member # 32786
If you want to leave the axle in the stock location and also interested in a "bolt on" above is the best way to go. They can even make you custom length and axle location I'm sure of it. Personally I went the cheapo flex route. Two sets of junk yard springs (52's front and 56's rear) and very happy with the flex. In fact I had to put a limit strap on the pass. side to keep from breaking another front driveline.
79' K10 350 F.I./ TH350/ NP203/NP205/D60/14FF & 42's 02' GMC crew cab D-Max 79chevyk10 everywhere else. Save The Hammers Rally Post #314 Tellico Rally Post #20 |
#12 (permalink) |
Member # 5738
I run stock 52"s up front and 56"s in the rear with a shackle flip.
1982 Chevy K5 Blazer 6.2 Diesel\SM465\NP205 Front: Dana 60 4.88 Detroit 1410. 52" Spring swap and a 4 degree tapered Zero Rate Rear: 14 Bolt 4.88 Detroit 1410. Disk Brakes. Stock 56" springs DIY4x Shackle flip and a 1" Zero Rate 38.5x14.50-15 SX's - 15x9 bead locked wheels [URL="http://www.pirate4x4.com/forum/showthread.php?p=6018956&posted=1#post6018956"]My Build Tread[/URL] |
#13 (permalink) |
Member # 92285
nice rig . i think i want to stay pretty close to stock as far 52 long but i am really thinking about doing 4" shackle flip with 6" HD shackles and a 1" leaf . that should give me 6" lift total . i think .
