Welding the 14 Bolt - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2007, 03:02 PM   #1 (permalink)
terminallance's Avatar
Member # 70465
Welding the 14 Bolt
Ok here is my question, I have been thinking of getting a locker for my 14 bolt, but seems like everyone that I talk to just says to weld it. Well I don't have a problem with that if it will be strong enough to hold.
I have heard many different ways to do it, but not to sure what one to do. I had seen on here on the tech section that ballivesta dosen't like welding the spiders together because of the enourmous stress loads that are placed on them while under load. I like the way he did his but am un-familiar with welding rear ends together.
Any advice and pictures that you could provide and post would be greatly apperiacted
Thanks again
Kyle
Knowledge is power, but Ignorance is bliss.
[QUOTE=sm1nts2escape;7210175]What gear ratio do I need for running 44" tsl's for a top speed around 115mph?Thanks[/QUOTE]
terminallance is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 03:10 PM   #2 (permalink)
RJR99SS's Avatar
Member # 77697
Depends what you're going to do with it. If this is a pure off-road machine, a locker is nice but a little too pricey. If you dont plan on driving it on the streets, i'd either get a spool, or just weld the spiders.
Welding them isnt very high tech, you just weld the spider gears together. I've known plenty of people who are hardly skilled welders that have done this to their 14 bolt and they've never broke.
RJR99SS is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 03:23 PM   #3 (permalink)
Member # 70465
This is a strictly trail truck
Old 08-14-2007, 07:16 PM   #4 (permalink)
Member # 97715
Just weld them up solid i doubt you will ever brake the weld you will chip the ring or pinion or break a U-joint or axle shaft first before a weld will brake i think... Im welding my 14 bolt in the next week or 2 hopefully ill post up some pics for you if your gonna wait...
Cheers
chev-head is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 07:58 PM   #5 (permalink)
Member # 72744
I am considering welding mine too. I had a welded 12bolt in my Nova and it skipped around corners. Will this get even worse with a 15.5 tire? My truck is a daily driver so i am wondering if welding it is realyl a good idea or not.
RRRAAAYYY2 is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 08:47 PM   #6 (permalink)
RJR99SS's Avatar
Member # 77697
If you got to drive it on the street, no it's not a very good idea at all. I'd go with a locker if it's on the street a lot.
Old 08-14-2007, 08:56 PM   #7 (permalink)
GMCTruxrule's Avatar
Member # 51243
welding a rear and DD it on the street especially with tires that wide is not very smart. Just Detroit it, they aren't that expensive.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 05:37 AM   #8 (permalink)
Member # 72744
Thanks, that is what I was thinking.
Old 08-15-2007, 06:44 AM   #9 (permalink)
Member # 70465
well mine isn't going to see the road, well maybe 20 miles a year thats to and from the trail, and any advice would be greatly appericated
Kyle
Old 08-15-2007, 08:42 AM   #10 (permalink)
RJR99SS's Avatar
Member # 77697
Well it's up to you. If you get a detroit, it'll work better on the street. With it welded, the rear is going to jump around and scuff the tires on a turn.
Old 08-15-2007, 11:01 AM   #11 (permalink)
Member # 21408
Mine is not a daily driver, but I have made several 200+ mile round trips to and from the trail with a welded rear diff. Handling on the street have never been an issue, and the only time it's noticable is making sharp turns in town or a parking lot (38x13 Swampers). They did cause the rear tires to wear noticably faster.
A friend also runs a welded rear and has had both 38x13 and 42x15 Swampers. He drove the truck on the road to and from the trails for years, including several trips out of state and again never had any issues. I never noticed as much additional wear on his rear tires versus the front, but it was a pickup so probably less weight on the rear.
For a DD, I probably would not run a welded rear but for a trail truck with a very small amount of road time there is no way I would spend the money on a locker.
With decent welds neither of us has had any failures. My friends truck runs a mildly built big block with the 42's and he's broken a 35-spline D60 stub, but not the welded rear.
6.2Blazer is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 01:02 PM   #12 (permalink)
Member # 15404
I have had ARB's and detroits in the rear before. Now everything (3 axles so far) get welded for the rear. If I drove my trail rigs as a DD I would probubly go with the ARB again....but realy a rear locker is not worth it. Spool it and foget it.
The only people I have seen break a 14bolt did that stupid fill-in-the-gaps style that was promoted on CK5; it would eventualy loosen itself up. However I have seen a couple of 14bolt detroits go after a rear shaft was broken.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 01:11 PM   #13 (permalink)
Banned
Member # 24704
If I didn't get a really good deal on a 14 bolt with a detroit already, mine would be welded.
Tim84K10 is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 07:21 PM   #14 (permalink)
tennessee rockhumper's Avatar
Member # 52201
he said it was a trail truck. and he's cool with welding it as long as its strong.
this site is going to hell.
none of you answered his question on the proper way to weld the damn thing.
1. tack the spiders to the side gears through the windows of the case. tacking it before you split the case insures it will go back together later. dont weld anything to the case.
2. split the case. weld up the side gears, spider gears and crosspins into a big ball.(better have plenty of gas and wire). you have now made it into a redneck mini-spool.
3. grind down the welded hunk until the welds dont prevent the assembly from dropping back into the case.
4. reassemble
the only way you will break it is if all 4 crosspins break at once. you will snap an axle first.
tennessee rockhumper is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 08:11 PM   #15 (permalink)
WSS
Member # 28159
Anyone have any pics?
WSS is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 08:40 PM   #16 (permalink)
Member # 70465
Yeah pictures would be great, I pretty much have a rough Idea of what to do but I would rather see something to make sure that I don't f*ck it up when I try to do it.
I had seen the Fozzy locker that CK5 was puttin out on there website, and thought that it just looked like it would screw something up
Thanks so far
Kyle
Old 08-15-2007, 08:44 PM   #17 (permalink)
Member # 70465
4. reassemble
Thanks for finaly answering my question
Old 08-15-2007, 08:52 PM   #18 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Here you go: Name:  bowdown.gif
Size:  265 BytesAll HAIL the ORB of TRACTION
BiggerValves gets credit,I stole his pic from this thread:
http://www.pirate4x4.com/forum/showt...ht=weld+orb%2A
guidolyons is offline   Reply With Quote Quick reply to this message
Old 08-16-2007, 07:25 AM   #19 (permalink)
Member # 70465
So you pretty much just fill all that full of weld and boom "mini spool"
Old 08-16-2007, 07:43 AM   #20 (permalink)
Member # 70465
I found this post and this pretty much looks un breakable
Old 08-16-2007, 09:09 AM   #21 (permalink)
Member # 69207
You'll break alot of other stuff before the ball of molten steel lets go...
bushluver is offline   Reply With Quote Quick reply to this message
Old 08-16-2007, 10:23 AM   #22 (permalink)
Member # 70465
Touche'
Old 08-16-2007, 12:33 PM   #23 (permalink)
Valley Auto's Avatar
Member # 78079
isnt a 14blt mini spool like less than 200 buck with the price of wire and gas theses days....
Master of the wire Wheel!
Valley Auto is offline   Reply With Quote Quick reply to this message
Old 08-16-2007, 12:40 PM   #24 (permalink)
Member # 70465
I don't know what the price is thats why I'm askin either weld it or spool it which is eaise and cheaper, right now looks like the weld is the way to go, but where can you buy mini spools at online
Old 08-16-2007, 12:58 PM   #25 (permalink)
VHD44's Avatar
Member # 42423
pics of a my welded gov-bomb..
VHD44 is offline   Reply With Quote Quick reply to this message
