Cutting for 42's - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2007, 12:14 AM   #1 (permalink)
Irork's Avatar
Member # 67272
Cutting for 42's
Hey guys. Im just about to order some 42" Iroks for the blazer.. and im sorta gettin gunshy. The truck has 6"softrides and a 2 inch body lift. It currently sits on 38.5 boggers and some moderate hackage of the front fenders... no rubs at all. BUT what im afraid of with the 42s, no matter what i do with my good friend "mr. sawzall" im going to be into the firewall pretty heavy. Do you think a couple hits with a big A$$ hammer will do the trick on the firewall enough to limit the rubs or will i HAVE to set the axle forward an inch or two?? Any experience or pictures would be great.
Heres a few pictures to show what im worried about..
this is before my first trim job... but you get the point
after the trimming
and the rear might be a adventure also...
'94 'Yota ext cab v6- 4 inch Trailgear SAS(6 inch shackle), 5" trailgear classic rear kit, 3 inch body, 36" bias Iroks
'84 K5- built 406 Small block, TCI tranny, 6 inch superlift springs front and rear, 2 inch body lift, 38.5 Boggers, 3/4 ton d44 front and locked 14bff rear
Irork is offline   Reply With Quote
Old 09-20-2007, 01:46 AM   #2 (permalink)
Member # 24772
Unless you have a bigger front axle (60?) waiting for install, I think it would be wise to re-direct the tire fund. But if you insist, there is always a bigger hammer and more sawzall blades.
72 K5 350/350/205 60/5.13/ARB 14/5.13/L.L. 4" T.C. Springs
1stGenK5 is offline   Reply With Quote
Old 09-20-2007, 02:31 AM   #3 (permalink)
greythorn's Avatar
Member # 89526
those are 38.5 boggers? how come they look so small? are they on a 17" rim or somthing? what width are they? also why are you switching from boggers??
Wheelordie.com its what your mother warned you about!
greythorn is offline   Reply With Quote
Old 09-20-2007, 03:26 AM   #4 (permalink)
Member # 55686
I ran the same set up with 39.5 TSL's. I made lots of contact with the firewall at full stuff and had LOTS more fender trimmed than you. Dont hit the fenders but they hit the cab and take lugs off. You are gonna need more lift or move the front axle forward a bit. I went to a D60 and a 8in spring and they cleared alot better. But no way i could run it with 42's. Your cab is gonna eat up your expensive tires.
84 Short Bed
Dana 60 14boltff
np205
6" pro comp 2" Body Custom 1" Shackles Up Front
39.5 tsl's Warn 9000 on 12in channel iron for a bumper
73Stpside is offline   Reply With Quote
Old 09-20-2007, 07:32 AM   #5 (permalink)
Member # 19031
Send a message via ICQ to gottagofast Send a message via AIM to gottagofast Send a message via Yahoo to gottagofast
bumpstops are your friend
Kevin
[URL="http://www.pirate4x4.com/forum/showthread.php?t=567624"]My build thread[/URL]
Killed the S-10 n2 jeeps now
gottagofast is offline   Reply With Quote
Old 09-20-2007, 07:41 AM   #6 (permalink)
Member # 69207
Like 73stpside said, move your front axle forward.
Incorporate a zero rate into your front leaf pack and move your axle ahead an 1 or 1.5" and trim your front fender and rad support right up to the headlights.
That's what I did on my last project.
I ran 39.5" Pitbulls with a 4" susp and 3" body, loads of sawzall and BFH = no rubbing.
bushluver is offline   Reply With Quote
Old 09-20-2007, 08:42 AM   #7 (permalink)
Member # 53382
Send a message via AIM to SouthernK5
im running 42" iroks on h1's with ~8" lift. my axle is moved forward 3.5" and the front is cut straight across just below the turn signal reflector thing and the back of the fender isnt trimmed much yet (about the same as what you have on the back of the front fender), but it doesnt rub yet, i havent really flex it out completely yet. sorry no pics
'85 k30 with crawl ratio of 140:1
'88 k5 on 39.5 iroks
muddybuddy on ck5
SouthernK5 is offline   Reply With Quote
Old 09-20-2007, 01:05 PM   #8 (permalink)
Irork's Avatar
Member # 67272
A 60 is definatly in the near future...
Old 09-20-2007, 01:06 PM   #9 (permalink)
Irork's Avatar
Member # 67272
Yup, they are the skinny boggers 38.5-11-16.5.
switchin to boggers because it is a bit of a drive to any wheelin spots or trails and i dont have a tow rig for it... so it gets driven. Boggers are horrible on the roads.
Old 09-20-2007, 01:09 PM   #10 (permalink)
Irork's Avatar
Member # 67272
Thanks for the input, thats kinda was i was expecting to hear. I definatly dont want to lift it anymore... so ill be movin the axle forward and might even go ahead and tub the firewall a few inches more then what i BFH could do.
Old 09-20-2007, 01:12 PM   #11 (permalink)
Irork's Avatar
Member # 67272
lame question... but any pictures??
Im curious to see the front of the fender.. Ill most likely try zero rates to see if thats enough to clear the firewall...
Old 09-20-2007, 05:45 PM   #12 (permalink)
Member # 80208
I would bag the 42's and buy a 60 first.
You'll have alot more fun on 38's and 1 ton then 42's and a dana 44.
76 fj-40, 400sb, 465, 35's.
89 blazer, tbi 350, nv 4500, 241, 60, eaton, 5.13's, 38.5 SX's.
J-Ohlin is offline   Reply With Quote
Old 09-20-2007, 06:46 PM   #13 (permalink)
Irork's Avatar
Member # 67272
ill need new tires anyway... because the boggers are GONE!! the are pretty much a street tire now haha, bald as a bogger could be
