Th400 torque converter question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-11-2007, 10:00 PM   #1 (permalink)
Member # 88672
I have a few th400 transmissions I'm trying to piece together 1 good one. Is there a difference between the 6 bolt and 3 bolt torque converters? I think the 6 bolt units came behind a diesel. I'm running a 454 is the 3 bolt unit a higher stall? Thanks for any help.
A... truck... kinda ... with stuff in it...
kitimatdude is offline   Reply With Quote Quick reply to this message
Old 10-11-2007, 10:06 PM   #2 (permalink)
Grumpy_old_fart's Avatar
Member # 20147
the 6 bolt converter was generally used in HD applications, and behind diesels. They have torrington bearings throughout instead of bushings. If the diameter is the same, 12 1/2 inches, then the converters could be the same stall, but the only way to tell is to hook them up.
Im betting that the 3 bolt has more stall. Im also willing to bet its not as tough.
Empathy, apathy, sympathy.
Sympathy is between shit and syphilis in the dictionary.
Grumpy_old_fart is offline   Reply With Quote Quick reply to this message
Old 10-11-2007, 11:01 PM   #3 (permalink)
Member # 88672
Thanks Grumpy_old_fart,
I was told by a "not exactly in the know" friend that you can use a th350 torque converter in a th400 for higher stall. Is that false? Or did he get lucky and get it right?
And what the hell happened to my sig?
Old 10-11-2007, 11:04 PM   #4 (permalink)
Member # 20147
youre buddy was correct, you can use the th350 converter in the 400.
as for your sig... i dunno. does mine work?
Old 10-12-2007, 06:52 AM   #5 (permalink)
Member # 100166
kitimatdude,
I am by no means a TH400 expert, but for what it's worth, my 454 had a 3 bolt convertor behind it. It was also in an 11,000lb GVW K30 ambulance chassis, so I would call that heavy duty in my book. Grumpy seems to know a lot more about them, so I'd trust what he says. Just wanted to let you know what I've seen.
Hope this helps,
Joe S.
K30_dump is offline   Reply With Quote Quick reply to this message
Old 10-12-2007, 08:07 AM   #6 (permalink)
Member # 13786
Putting in a 350 convertor such as a C9 --- on the average--- can bring the stall up to about the 2300-2600 range---depending on the engine torque-- It is done A LOT.
KWTMECH is online now   Reply With Quote Quick reply to this message
Old 10-12-2007, 11:04 AM   #7 (permalink)
Member # 20147
shhh dont tell em "C9" or "C3" cause they will think its a ford hybrid.. you and I know better, though....
Old 10-12-2007, 12:41 PM   #8 (permalink)
Member # 13786
ooooooops ----my bad
Old 10-12-2007, 05:48 PM   #9 (permalink)
Member # 88672
Now I gotta run out and see if the torque converter for my c4 fits
I looked at my shop I have 1 th350 there I'll check what numbers it has on it tomorrow.
I have two of those six bolt th400 torque converters. one has metric bolts the other doesn't. I assume the metric one is later. I don't think I'll use either.
Old 10-13-2007, 11:40 AM   #10 (permalink)
FORDPLAY's Avatar
Member # 62032
i have a like new 10" 3500 stall...for a big block..
FORDPLAY is offline   Reply With Quote Quick reply to this message
Old 10-13-2007, 02:00 PM   #11 (permalink)
Member # 13786
Does a big block really need 3500 worth of stall?
Old 10-13-2007, 03:12 PM   #12 (permalink)
Member # 88672
There are no numbers on the TH350 converter I have. only thing I found was a letter "B" no idea if that means anything. its about 11" in diameter so not a high stall, but no doubt higher than my 6 bolt 12" current one.
